Throttle Locks? - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismHonda PowersportsNew Bonneville
Old 10-17-2008, 11:59 AM   #1 (permalink)
Favourite Bike: '08 Speed Triple
Other Motorcycle: '07 HD Softtail Deluxe
Throttle Locks?
I'm a new S3 owner who's been riding cruisers with throttle locks for the past few years. They give an old guy like me a rest on highway rides.
Are there any available for this bike? Does anyone have one installed?
Also, I picked up a pair of Progrip gel grips, but it looks like I may have trouble getting it on the throttle side. Has anybody installed these on his or her bike? Any tips?
Are there any particular brands of gel grips that work well on these bikes?
Thanks for any advice.
MoChucker is offline   Reply With Quote
Old 10-18-2008, 12:41 AM   #2 (permalink)
Favourite Bike: '07 Scorched Yellow S3
turbolc2's Avatar
Other Motorcycle: Pontiac G8 GT 6.0L
We will probably get flamed here but I put this on my bike, an '07. A bit expensive but I feel like it's the best outside electronic cruise. Sure gives the 'ol hand a rest....
http://www.brakeawayproducts.com/
The First Step in Stopping Racism, Get Rid of All the Different People
turbolc2 is offline   Reply With Quote
Old 10-18-2008, 12:54 AM   #3 (permalink)
Thanks for the reply. I'll probly go with that one or the Throttlemeister. I'm too old to worry about gettin flamed.
Old 10-18-2008, 02:57 PM   #4 (permalink)
Favourite Bike: '01 Speed Triple
A cheap way to get a throttle lock is to get an o-ring and put it between the grip and cable housing. No off setting though.
Speed3 is offline   Reply With Quote
Old 10-18-2008, 08:14 PM   #5 (permalink)
silentrider's Avatar
What Breakaway did they send you Turbolc2 ?
Reason i ask i have a Breakaway thats still in the Box that i bought for My M109R but never Installed,I'm sure i can get it to work on the S3 cause it comes with the three different Rubbers for the grip but i was wondering what Number was on the Box you got thanks for any info :~)
The number on mine is PN 5CP02
silentrider is offline   Reply With Quote
Old 10-18-2008, 08:22 PM   #6 (permalink)
Favourite Bike: what day is it?
SalsaShark's Avatar
1. I was looking at throttle locks at the beginning of the summer. I ran out of time and ended up picking up a crampbuster instead. It's still on the bike and I believe it's the best 11 bucks I've spent on any motorcycle accessory. Easy to put on (and remove if necessary), and helps a ton on long rides. I did an IBA the day after and had more problems w/ my left hand than my right during the ride.
2. I put a set of the gel grips on my 919. Cut the old ones off, squirt a tiny bit of dish soap and rub around the inside of the gel grip. They should slide on quite easy, then the soap will help glue them in place. A little trick I picked up when I was slaving away for my dad pulling wire through long conduit runs.
www.cocsba.com
SalsaShark is offline   Reply With Quote
Old 10-18-2008, 08:42 PM   #7 (permalink)
Favourite Bike: '07 Speed Triple
Bohdan's Avatar
Other Motorcycle: '10 Ducati Streetfighter
Extra Motorcycle: '01 SV650
Originally Posted by SalsaShark View Post
2. I put a set of the gel grips on my 919. Cut the old ones off (...)
What the heck is with this idea of cutting grips off? It could be easily done without this, 2 minutes job. Lift the edge of grip, slide the little tube on WD-40 can under as far as it goes and squirt while pulling back. Twist the grip and remove it. Then wipe off and clean surface off oil, use Windex to squirt inside the new grip and slide it on.
Done this many times. I know people who bought second hand bike with non-stock grips, hate them and want back to OEM. Sell yours on e-bay, make them happy.
Bohdan is offline   Reply With Quote
Old 10-20-2008, 11:01 AM   #8 (permalink)
SalsaShark's Avatar
I never said it was a best practice, but it worked for me...
I'll try not to anger the motorcycle gods the next time I do a grip swap.
www.cocsba.com
Throttle locks Aesculapius Speed Triple Forum 2 05-14-2008 02:17 PM
installing throttle locks keko Twins Technical Talk 4 07-12-2007 11:32 PM
throttle locks / cruise controls DJRenton Sprint Forum 11 03-10-2007 07:16 PM
throttle locks mag10 Twins Talk 6 04-13-2006 09:20 AM
Throttle Locks JasonS Sprint Forum 10 03-25-2005 02:38 PM
