Front brake "humming" noise - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 10 (permalink) Old 10-08-2008, 12:43 AM Thread Starter
Main Motorcycle: '07 S3
About two months ago a got new brake pads - both front and back. After this I noticed a "humming" noise from the front brakes while stopping (rear brake is fine). Only thing I can compare the noise to is a metal wire vibrating in the wind. The vibration is also noticeable. Not severe, but can definitely feel it.
Before the brake pad replacement the brakes worked perfectly.
The braking action is still good, but not as good as it used to be. Takes a little longer, and a little more force to come to a stop.
I figured this was normal on new pads and it would go away as they broke in, but after two months and close to a thousand miles there has been no change.
What do you recommend I do?
Thanks for the help!
fuzbox is offline
post #2 of 10 (permalink) Old 10-08-2008, 10:32 AM
silentrider's Avatar
I would have the rotors turned ....resurfaced,or you could rough up the surface yourself and see if that helps,It's always a Good ideal to Prep the surface of any Brake Rotor, Bike or Cage before Installing New pads,Gives a Lot Better Bite,and smooth braking........IMHO
silentrider is offline
post #3 of 10 (permalink) Old 10-08-2008, 11:08 AM
Main Motorcycle: 2008 Speed Triple 1050
Darkhorse's Avatar
My front brakes have "hummed" since I picked her up from the dealer in august. Sounds like a whirring noise. They squeal a lot, too, if i'm not full on em.
Seems normal to me.
Darkhorse is offline
post #4 of 10 (permalink) Old 10-08-2008, 11:20 AM
Main Motorcycle: Speed Triple
Other Motorcycle: Ducati Street Fighter
Did you replace your pads with OEM pads? or aftermarket pads such as SBK Carbone Lorraine, or EBC HH?
If aftermarket...it sounds like what I did in a rookie move awhile back. The sintered aftermarket pads consist of a material that is too "aggressive" for stock rotors!!! Started off with a humming...excessive noise in gerneral when I brake. Then some vibration when I braked......then, ultimately, over time, my brake lever started to pulse in my hand when I braked.
Turns out the pads were warping the stock rotors. I put on some Braking Wave rotors and everything was PERFECT.
29138 is offline
post #5 of 10 (permalink) Old 10-08-2008, 01:41 PM
DGA
DGA's Avatar
I replaced my front pads with EDC HH about 4,000 miles ago. Two things I noticed were the "humming" and that the EDCs need some heat put into them before they start to bite as the factory pads did. Once they are up to running temperature though, they tend to have more initial bite and stronger stopping power. No sign of warped rotors.
DGA is offline
post #6 of 10 (permalink) Old 10-08-2008, 04:43 PM
Main Motorcycle: '01 Speed Triple
I used EBC HH pads with the stock rotors for 15,000 miles without a problem. They don't hum so much as they go zzzzzzzzz when i'm hard on them. Now I've got ABM rotors on the front, and they don't zzz as loud now. I'd say it's normal.
Speed3 is offline
post #7 of 10 (permalink) Old 10-09-2008, 01:01 PM
Didn't say aftermarket pad material will DEFINITELY warp your rotors. But it happens...it's known, common info...it happens. If you do aggressive riding it can very well happen. It certainly did to me.
Not everyone buys a bike like this to commute, scoot around town, with an occassional ride through a canyon twisty. Some folks ride the bike to its limits and, sometimes, the stock parts aren't up to it. lol
29138 is offline
post #8 of 10 (permalink) Old 10-10-2008, 08:30 AM
I only ride my bike to church on sundays. And never go over the speed limit.
Speed3 is offline
post #9 of 10 (permalink) Old 10-10-2008, 09:59 AM
Bless you my child.
29138 is offline
post #10 of 10 (permalink) Old 10-15-2008, 04:18 PM
Main Motorcycle: 2007 S3
Other Motorcycle: Cb350
Yup- zzzz s with EBCs. No change in stopping power.
Zip
"Only by challenging and questioning our beliefs can we come to the point of ownership of those beliefs."
Major Kong is offline
The "Brake Issue"...Final Chapter rjb340 Speed Triple Forum 19 04-18-2009 09:52 AM
Front Brake "warpage" PfM Air Cooled Twins Technical Talk 2 07-21-2008 09:35 PM
"buzz" with front brake jonathanrsr Hinckley Classic Triples 11 07-05-2008 03:54 PM
Combining my "seat heat" and "tune" threads here TheNomad Sprint Forum 10 06-02-2008 12:09 PM
