On 2005-04-15 09:01, bikeordie wrote:
On 2005-04-15 07:03, gr8shandini wrote:
Look at how it just bolts on there. Triumph wants you to take it off.
yeah, i noticed that. i also noticed that the new license plate holders that you can buy still have the mounts for the turn signals on the sides of it. and once you take of the rear fender, the turn signals wont fit with the exhaust cans on either side. any ideas??
Triumph
wants you to take those cans off.
Serously though, without looking at it, I can't tell you if you can do it but I know that sometimes you can flip the turn signal brackets around, so that the panel against which the signal stalk is bolted is towards the inside- this brings the signal about an inch farther from the pipe. I own an '02 S3 and mounted my pipe is mounted kind of high, so I encountered a similar problem. But flipping the mount solved it (although, I still have only about an inch between my signal and my pipe, but that's enough for me).
