Trident-Exhausts.comAdvanstarMotorcycleShowsMotorcycle.comBikeBandit
ShopTriumph.com
Old 04-13-2005   #1 (permalink)
Urgent help needed, 05 Speed Triple due soon! Iam a vertically challenged rider,5ft 6ins. Has anyone experience with lowering rear suspension by about 1.5ins or 35mm? To give a seat height of 775mm.No problem with the front end as the forks can be dropped through the triple clamp. :hammer:
Old 04-13-2005   #2 (permalink)
Old 04-13-2005   #3 (permalink)
I'd just try it stock and set the sag properly. I'm a whopping 5'7.375" (after a full stretch first thing in the morning )
and I weigh 210. The suspension allows me to have both feet almost flat footed at a standstill, without any worries.
Good luck with the bike. You'll love it.
Sir_Loin is offline   Reply With Quote
Old 04-13-2005   #4 (permalink)
Old 04-13-2005   #5 (permalink)
Kiwirider,
A little more info since we last talked about this. As delivered my S3 was too soft on preload up front, and to stiff at the rear. I think 3 lines showing on the forks, and ring about centered on the shock.
To get the correct sag at the rear I have about the same thickness as the jam ring remaining of threads showing.
For now I have left the front, may stiffen this half a turn.
All this lowered the ride height some. I can do one "ball of foot" now, vs one toe. This is enough for me.
I am 5'4" approx 175lbs, approx 28.5" inseam with Columbia hiking boots on.
I thought that I remember reading here that the bottom link from a Daytona was the same, and there are replacement links that lower a Daytona.
Hope this helps in some way.
mdallas is offline   Reply With Quote
Old 04-13-2005   #6 (permalink)
Kiwirider,
Old 04-14-2005   #7 (permalink)
mdallas
the lower link is the same as the Daytona (well it has the same pt # stamped in it and looks identical)
I have been looking for a link to lower a Daytona and haven't found one. Do you recall where you have seen one?
I am a wee bit over 5' 6'' and cannot get the balls of my feet down on my 05 S3. Not comfortable with this and so am looking to drop the bike a fraction. I haven't played with the shock yet but figured that it would get me a little closer to the ground (being 250lbs will help with this). I would like to get to the point where I can easily get 1 foot down flat and be on the ball of my foot on the other leg.
Lowgloss is offline   Reply With Quote
Old 04-14-2005   #8 (permalink)
I'm 4'11" and 310 lbs and have no probl... :-D
Sorry
Rama is offline   Reply With Quote
Old 04-14-2005   #9 (permalink)
My mother in law is so fat, she broke her leg and gravy came out.
Old 04-14-2005   #10 (permalink)
Ba Da Bing! :-D
Supposed to get my mirrors in today. Thanks, Sir Loin. Beautiful day here..rain is gone..heading out for a ride.
Life is good
Took my first ride on a Speed Triple today.... Drunktank Speed Triple Forum 8 11-20-2006 01:30 PM
Ride height adjustment - Speed triple 2006 Moltzi Speed Triple Forum 10 11-15-2006 10:40 AM
DEMO RIDE ON 05 SPEED TRIPLE TRISPEED Speed Triple Forum 0 04-01-2005 12:25 PM
first test ride on 05 speed triple Speed Triple Forum 5 03-20-2005 07:23 PM
Speed four/triple lower seat height Knightshade Speed Triple Forum 0 03-28-2004 08:32 PM
