Help - Oil pan replacement - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 09-13-2008, 11:23 PM   #1 (permalink)
Unhappy Help - Oil pan replacement
Oil pan drain plug over tightened resulting in striped threads in the oil pan (MY OWN FAULT). Tried a few options eventually ruining the oil pan, crack/split up the side of the drain plug.
Dealer quoted $360.00 for replacement.
Are there any better prices for replacement oil pan???
jonesw is offline   Reply With Quote
Old 09-14-2008, 10:44 AM   #2 (permalink)
Favourite Bike: '01 Speed Triple
In the States, you could try Baxter cycles, or contact Sandy at www.triumph-ant.com. He is a breaker in Wales, and even with shipping, you should make out.
Speed3 is offline   Reply With Quote
Old 09-15-2008, 01:01 PM   #3 (permalink)
Favourite Bike: 2003 Speed Triple
PhilM's Avatar
Can it be welded?
PhilM is offline   Reply With Quote
Replacement key? NoDice Biker Hang-Out 6 07-26-2008 06:34 PM
Replacement Key Blackhead Hinckley Classic Triples 2 05-31-2008 07:42 PM
Replacement key ROBD Twins Technical Talk 3 04-22-2007 02:09 PM
What replacement can? doodledog Daytona Deliberations 5 09-17-2006 09:44 PM
Cat replacement?? miketango The Rocket Science Forum 20 06-20-2005 09:42 AM
