Hi, I have a 2005 1050 Speed triple with 4700 miles on the clock.
The Tacho stopped working about 12 months ago when the bike was just out of warranty.
Only the rev counter needle does not work. All of the other instuments and lights on the clock cluster work fine.
The rev counter needle does not do its initial 'sweep' when the ignition is turned on, nor does it work when the engine is running.
My local Triumph dealer is quoting me nearly £700 for the clock cluster.
Is it likely to be the whole cluster that needs replacing, or is there a relay or sender somewhere that could be at fault?
Any experience in this area appreciated.
Cheers
Ade
