08-09-2008, 05:05 PM
Newbie
engine noise
Anyone heard of this problem? I have a new (900 Miles) 2007 Speed Triple. About 100 miles ago I started to hear a very apparent "ping," possibly comming from the top end, but not sure. It doesn't happen until I shift up from 1st gear, but is prevalent from there on, regardless of rpm. This is my first Triumph, but I've had lots of other bikes and this doesn't sound normal at all. I just dropped the bike off at the dealer. Thanks for any input.
08-09-2008, 05:15 PM
SuperStock Favourite Bike: 2002 Harley FXDWG
Posts: 220 Other Motorcycle: 1979 TR7V
Like an octane ping? What grade of gas are you using? Is it possible you got a tank of 89 octane?
08-09-2008, 06:11 PM
SuperBike Favourite Bike: 06 Speed Triple
Posts: 1,443 Other Motorcycle: 99 SV 650 Extra Motorcycle: 03 WR250F
89 octane is correct for US models...
insert clever saying here...
08-09-2008, 06:19 PM
Could still be a bad tank of gas.. either way the dealer should get to the bottom of it and it's under warranty so it should be no issue. Personally I will only go to name-brand gas stations just in case. Once I filled up my Seca only to have it begin running poorly and backfire the next time I started it. Had to dump the tank of gas, it had water and other junk in it, caused damage to my starter. Needless to say I never went back to that gas station.
08-09-2008, 06:25 PM
Formula Extreme Favourite Bike: 2007 S3
Posts: 420 Other Motorcycle: Cb350
On hard acceleration, initially, mine always sounds like it's detonating. I run 92octane in it. The compression ratio is 12:1, so it is a stratified charge engine. I was really concerned at first. I think it is just the air injection reeds catching up to the change in engine speed. I have not seen any indication of engine detonation in terms of engine performance.
I don't worry about it anymore.
Zip
"Only by challenging and questioning our beliefs can we come to the point of ownership of those beliefs."
08-09-2008, 09:38 PM
I'll bet you money that the "pinging" you are hearing is in fact a slightly tight chain in need of cleaning and lube. The S3 really prefers the chain to be on the loose end of the recommended chain slack.
I've gone through this exact situation. I could've sworn it was pinging, changed gasoline brands, octanes, etc...but in the end, the chain was simply a little tight and required some TLC. When I did this, the "pinging" magically disappeared.
Even if you think I'm completely daft, please try my advice. The worst that can happen is that you're out a half hour and your chain looks and works great!
One day I got pulled over for speeding. The cop said, "don't you know the speed limit is 55 miles per hour?" I said, "yeah, I know...but I wasn't going to be out that long." - Steven Wright
08-10-2008, 02:12 AM
Newbie
engine noise
Fantastic input, which I appreciate very much. I have indeed been using 89 octane (recommended in my owners manual), but will of course try running a higher octane.
Very interesting comment about the chain; my riding buddy told me he thought he had a clinking coming from the chain as we were riding side by side. Depending on what the dealer says, I'll certainly try both of these remedies. Thanks, again, for the replies.
08-13-2008, 12:25 PM
Supersport 600 Favourite Bike: 2008 Sprint ST
It is probably pinging from the gas. Being a 12:1 compression engine 89 octane is far too low. I would run no lower than 92, we are lucky enough to have Sunoco 94 octane in the midwest.
2008 Sprint ST 1050
Heated Grips, Tail Tidy, D&D Exhaust, TOR Tune, Power Bronze Double Bubble Screen, 520 Chain Conversion W/ 18/42 Sprockets, GSX-1300R 6-Piston Front Calipers, Smoked Integrated Tail Light.
08-13-2008, 12:39 PM
Newbie
engine noise
Thanks for the response. The bike is still at the shop and I haven't heard from them, yet, but I am definitely going to be putting 92 octane upon its return. 92 is what I put in my Valkyrie and XR's, but the S3 is my first new bike in a while so I thought I follow the manual's recommendation. It will be interesting to see what the dealer's mechanics say. Thanks, again.
08-13-2008, 06:44 PM
SuperStock Favourite Bike: 07 speed triple
Posts: 242 Other Motorcycle: someday 1078 brutale Extra Motorcycle: 06 kx450
it sure will be interesting
i started with 89 and went to 91 or 92 after awhile and i consistently get 39 mpg,4 more than before
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Engine Noise?
Yimm |
Sprint Forum |
17 |
02-19-2007 09:09 AM |
Engine noise
Triple_Rider |
Speed Triple Forum |
7 |
02-14-2007 02:09 PM |
Engine noise
PhilM |
0 |
09-10-2006 03:14 AM |
Engine noise
tjhugo99 |
Sprint Forum |
4 |
07-13-2006 11:31 PM |
Engine noise when hot
Black06 |
Twins Talk |
13 |
07-07-2006 11:16 PM |
