Break in service is an oil and filter change. From what I can tell, the original oil in the bike is a break in oil, not meant for high or constant RPMs.
That being said, constant Highway RPMs is a BAD idea. The first 100 miles of break in are the most critical and should be slow speeds with many many RPM and gear changes. This properly polishes in the cam lobes and buckets along with seating rings and bearings.
I would not ride the Highway home, take back roads. Riding a brand new bike that far isnt a good idea anyway. If there are factory defects, a loose coolant hose, bad wiring, its going to show up in the first 100 miles or so.
