BikeBanditMotorcycle.com
Old 07-05-2008   #1 (permalink)
Favorite Bike: 2007 Triumph Speed Triple
King Tut's Avatar
Red Plastic Plug in the Neck
I noticed today that the bike has a red plastic plug in the bottom of the neck. I know that plugs like that are normally used when shipping things so that stuff doesn't get in the hole. I was wondering if it was supposed to be left in or can be removed. It is pretty easily viewable from the front.
King Tut
2007 Triumph Speed Triple: Coming Soon
2004 BMW M3 Coupe: m3.civichatch.com
King Tut is offline   Reply With Quote
Old 07-05-2008   #2 (permalink)
Ferris's Avatar
Mine is there too. I gathered it was to stop crap from getting up there.
Ferris is offline   Reply With Quote
Old 07-06-2008   #3 (permalink)
plug
The plug is removed when you use a front wheel stand to support the front of the bike-a front wheel stand, like a Pit-bull, has a metal cylinder that goes in the hole to stabilize the bike as you raise it up on the stand. You can remove the plug with some needle nosed pliers, and push it back in when you take the stand out. I leave it in to keep any water getting up there when commuting in the rain
motonut is offline   Reply With Quote
Old 07-06-2008   #4 (permalink)
if you remove it, the is usually some head bearing grease dropping out of there.
then people post threads that 'why there is grease on my bellypan'
JT
jaket is offline   Reply With Quote
Chrome neck? Finkenator9 The Rocket Science Forum 0 07-27-2007 04:24 PM
Loose neck ! Anchorbend Twins Talk 1 10-18-2006 05:01 PM
Pain in the neck! 95bravo Twins Talk 16 07-06-2006 06:52 AM
neck up scooterscum Twins Talk 8 06-14-2006 05:20 AM
Neck Pain wonderdog Twins Talk 10 04-08-2006 09:31 AM
