engine smoke is this normal? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 9 (permalink) Old 06-26-2008, 05:59 PM Thread Starter
I know the basics blue=burning oil, black=to rich etc....i just recently started up the s3 and did a few revs and it puffs out a little puff of grayish black smoke. Im not familar with fuel injected engines so is this normal or what, bike only has 4500 miles and am running full synthetic oil. I should add that the engine wasnt very hot..the guage was barly past the top cool mark. Could it be the injection giving the engine more fuel for cold starts? kinda like choking a carb. It smoked just like i had a choke pulled out and reved it up. It doesnt do it at idle or anything...i just took it for a spin, got it up to temp and it doesnt do it nearly as much. I think it might be a little on the rich side. thanks
sandslinger17 is offline
post #2 of 9 (permalink) Old 06-26-2008, 08:43 PM
Main Motorcycle: Speedy!
I'd say you have picked it correct as running rich after a cold start.
Mine does the same, puffs black smoke with a quick flick of the throttle when cold.
Deano
sss1200 is offline
post #3 of 9 (permalink) Old 06-26-2008, 08:49 PM
Main Motorcycle: Speed Triple
White smoke indicates a blown head gasket with coolant getting into the cylinder.
Do a compression check on each cylinder to verify.
TripleZ is offline
post #4 of 9 (permalink) Old 06-26-2008, 08:52 PM Thread Starter
thats good to hear its not just me this time. Other than that it runs fantastic.
post #5 of 9 (permalink) Old 06-26-2008, 08:54 PM Thread Starter
its not white smoke. Its Blackish
post #6 of 9 (permalink) Old 06-26-2008, 09:10 PM
Main Motorcycle: 05 Sprint ST 1050
Sticks's Avatar
Extra Motorcycle: Wife's Bonneville America
When I start up my 97 S3 I always get grayish smoke for 10 seconds or so. I won't even touch the throttle for about 1 minute after starting it.
I hope your Black smoke is nothing more than carbon build up. With these high performance engines I tend to get my bike up to 8000 RPM or higher on regular bases. Do you tend to ride your bike hard or motor around town in a lower RPM range?
Sticks
Sticks is offline
post #7 of 9 (permalink) Old 06-26-2008, 09:42 PM Thread Starter
i just got the s3. The previous owner had it for 4 years and only put 1300 miles on it and i think he babied it. Yours smokes gray for 10 seconds after starting? whats that from? I think its just carbon build up with combination of running a little rich when cold.
post #8 of 9 (permalink) Old 06-27-2008, 03:12 AM
it can, but usually the white smoke is then so thich, you fills the world and you cannot see ****.
little white smoke is totally normal for a cold engine. it's just air moisture condensating to the pipes. Also fuel burning generates water to the exhaust.
jaket is offline
post #9 of 9 (permalink) Old 06-28-2008, 01:48 AM
sonnyboy11's Avatar
Agreed.
Many Speed Triples puff white smoke on start up and most Triples probably have a little vapor 'spittle' you'll see if you put your hand over one of the exhaust tips. Especially with the stock cans on a cool morning. It does not mean you have a blown head gasket.
sonnyboy11 is offline
engine back fire, normal? kidkazi Air Cooled Twins Technical Talk 16 06-21-2007 11:32 PM
Smoke IainG Speed Triple Forum 1 05-12-2006 04:46 PM
So I'm assuming smoke is bad... porsche996 Trophy 5 01-18-2006 03:52 PM
Normal engine temp? glw The Rocket Science Forum 3 09-28-2005 10:12 AM
What is a normal engine temp? Sprint Forum 6 05-24-2004 04:28 AM
