Originally Posted by gonzojournalist
The key with a RFID enabled transponder module
Triumphs do not have that. Cost savings etc. Matching template keys available at any locksmith down the road. Will work; no probs.
The ECU with stored code and response circuitry to both communicate with the transponder and allow or deny ignition or fuel delivery.
None of that either.
The gauge cluster with stored code.
Would make sense, but:
1) the dealer service manual gives no steps for pairing ECU+gauges
2) the change of gauges literally took a minute at my local dealer, where every time they have to break out the dealer gameboy it takes at least 20 minutes for them to figure it out
-> I'm 90% sure no pairing needed.
mileage tampering by replacement
None of that in Triumphs either. Mileage is stored in gauges only. ECU knows nothing about it. Replacing gauges will change mileage to the one stored in the gauges. New gauges will drop your mileage to zero.
In order for the system to operate again you'll either need the Triumph Service Tool used to communicate with the ECU or to take the motorcycle to a Triumph certified dealer and allow them to do so.
Nope. My bet is that any correct version gauges for 1050 Triple, instead of the 675 ones will work.
