400mi broken shifter shaft - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearOntario TourismMotorcycle.com Classifieds!Honda Powersports Motorcycle.com
Old 05-29-2008, 08:05 PM   #1 (permalink)
Favourite Bike: 08 speed triple
Other Motorcycle: 05 Buell xb12R
Hey new to the forum. Just bought a 08 speed triple a week ago and already have a broken shifter shaft. Ride bike for a week, down for two to fix it. dealer says it was a poorly machined part. just curious if anyone else has had this problem?
doublet is offline   Reply With Quote
Old 05-29-2008, 09:04 PM   #2 (permalink)
Favourite Bike: 2007 Speed Triple
I haven't heard of that before but it obviously a possible situation.
Welcome to Triumph, hopefully this will be the last thing you have to deal with!
Night Train is offline   Reply With Quote
Old 05-30-2008, 12:08 AM   #3 (permalink)
Favourite Bike: '07 S3
Other Motorcycle: V-Strom
Extra Motorcycle: VFR
Same thing happened on my '07 (at about the same mileage).Luckily I was stuck in 3rd only a few miles from home.Was it the shaft that broke or the bellcrank from the trans? My bellcrank was stripped out at the linkage end. Safety-wired it for about a week while waiting for parts and wired the new one "just in case". I told the dealer that it looks like it was cast out of cheese.
NC-S3 is offline   Reply With Quote
Old 05-30-2008, 09:12 AM   #4 (permalink)
I was stuck in 4th with my girlfriend on the back. that was a fun ride home. how long did it take them to get your part? mine is being shiped from the uk and will hopefully be to triumph in atlanta the begining of next week. then they will ship it to the local dealership. hopefully it will be back together soon.
Old 05-30-2008, 09:15 AM   #5 (permalink)
The one of the teeth on the shaft broke. From what i was told there is two teeth. witch ever tooth allows you to downshift is the one that broke off. but they found it in the bottom of the sump.
Broken shifter shaft ClassiclyMobile Hinckley Classic Triples 40 02-22-2011 05:37 PM
Help...broken Shifter britishsteele Maintenance Tips and Tricks for the T3 Classics 33 02-22-2011 08:42 AM
Need tech. info: shifter shaft replacement, priming oil system eighty6gt Speed Triple Forum 5 12-01-2007 03:36 PM
Gear shifter shaft removal dat Twins Technical Talk 3 06-11-2007 10:41 PM
Shifter shaft seal smartin108 Tiger Workshop (archive) 2 01-21-2006 10:15 AM
