I have Pitbull stands for both the front and rear. great quality, very stable. don't know the pin sizes.
I have the reversible rear stand (can be used on either side of the bike, depending upon what you're doing to it.
I also have the newer front stand that lifts the bike up from the lower triple tree so you can remove the forks for fork oil changes and such.
I have no experience with the ABBA stand, but one advantage I could see is that you can support the rear of the bike, allowing you to dismantle the rear (for example, for rear bearing service); however, I was able to do this by simpling using a scissor jack under the rear dog link.
