Suspension set up( kinda long ).... - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com Classifieds!Honda PowersportsNew BonnevilleOntario Tourism
Old 05-28-2008, 11:40 PM   #1 (permalink)
Favourite Bike: '07 Scorched Yellow S3
turbolc2's Avatar
Other Motorcycle: Pontiac G8 GT 6.0L
I've done the searches and I've done the Google search. My question is, what have I done???
As I understand it, Triumph sets the bike up for a 175lb.ish rider. I am 220lb.
From gostar-racing.com:
Front Preload
Some people set the front suspension based on rider sag and static sag....Rider sag (35-48mm) and Static sag (25-30mm).
Originally I couldn't get the rider sag to the correct specs. I started with approx. 24mm of rider sag and 3 lines showing. I backed the preload adjusters out to 5 lines showing and couldn't get better than 30-32mm.
It kind of dawned on me that heavy rider = more preload, not less, so I screwed them in to 2 lines showing.
Wow my bike has made a 180* turn. More stable at speed and turns a lot easier.
My question. If changing the front made such a change what will changing the rear do?
Should I mess with rear spring preload? If so what's a good starting point?
Is it possible the static sag and rider sag numbers above are reversed?
Sorry for the length. I'm sure some other questions will pop up after some responses...
Thanks...
The First Step in Stopping Racism, Get Rid of All the Different People
turbolc2 is offline   Reply With Quote
Old 05-29-2008, 01:53 AM   #2 (permalink)
Favourite Bike: Speed Triple
Other Motorcycle: Ducati Street Fighter
I'm 220lbs also. take this with a grain of salt and do what ya gotta do but....
At our weight the rear shock is useless. Those that don't think so, and are our weight, obviously don't tax the the bike the way it's supposed to be.
If you ride the track or aggressively ride through canyons/twisties....the rear shock can't be adjusted adequately enough for us...period. I worked it and worked it and worked it and even broke down and paid $36 to have it adjusted by a local "pro" shop. Even THAT shop agreed....I'm too heavy for teh stock rear shock.
Bought an Ohlins and WOW. WOW. WOW.
29138 is offline   Reply With Quote
Old 05-29-2008, 10:35 AM   #3 (permalink)
Favourite Bike: mine
k1973's Avatar
Originally Posted by S3Junkie View Post
I'm 220lbs also.....I'm too heavy for the stock rear shock.
ARGHH !!!! don't say that.... now I'm going to have to spend more money...... I'm only at 215, and losing weight is just not an option
k1973 is offline   Reply With Quote
Old 05-29-2008, 10:55 AM   #4 (permalink)
turbolc2's Avatar
Thanks for the reply. In your opinion did I do the right thing up front? I don't do any track riding,just "spirited" street driving.
Any who, it seems like I went opposite of what Was writen in all the suspension articles. I guess if it works it works.
Old 05-29-2008, 11:23 AM   #5 (permalink)
Favourite Bike: '07 Triumph Speed Triple
BEEMERPECKER's Avatar
Other Motorcycle: '00 BMW R1150GS
Ohlins, Wliburs, Penske or any quality shock will provide a superior ride to the stock Showas, but I believe you can get around the rider sag issue by installing a stiffer rear spring. Much cheaper, but not as effective fix.
BEEMERPECKER is offline   Reply With Quote
kinda freaking out...kinda excited Mattrat Twins Technical Talk 11 11-20-2007 08:05 PM
New Guy....Here is my rant, kinda long, need help! Ryan_TT Triumph SuperSports 9 06-20-2007 05:34 PM
I think I'm getting the suspension sorted out - Long ohiorider Twins Technical Talk 10 08-13-2006 10:41 PM
CRG Hindsight LS, Owners opinions........kinda long GrendelPrime Speed Triple Forum 17 02-15-2006 03:07 PM
Frame sliders (kinda long) GrendelPrime Speed Triple Forum 5 08-12-2004 01:25 PM
