BikeBandit
Old 05-14-2008   #1 (permalink)
Best tuneboy tune for 2006 w/o SAI ? ?
I PM'd a couple of users on here but I have yet to get a response so I figured I'd float this request out there. I just removed the SAI on my '06, removed the pre-cat, ported the headers, and ceramic coated the pipes. The information on the tuneboy site is a little confusing so I cannot confidently choose one of the listed tunes. Despite two attempts, I was not able to get a response from tuneboy support either. The tuneboy site lists tunes according to VIN and fuel tank material (plastic or metal) However, I have a plastic tank but the VIN for my machine falls under the metal tank listing on the tuneboy site. So, I'm not sure which tune to pick. I plan on riding speedy 120 miles to a dyno shop after I get a tune in it, but I want to be sure to get a tune that will not run lean and cook my engine and/or my nicely ceramic coated pipes. Can anyone recommend the proper tune ?
Thanks,
BulldogHooligan is offline   Reply With Quote
Old 05-14-2008   #2 (permalink)
oops, forgot one detail
I forgot to mention that I also have an aftermarket single straight through exhaust silencer.
Old 05-14-2008   #3 (permalink)
I've had the same problem with no responses from Tuneboy customer support on another issue. It's sad that a product that needs good support due to a lack of proper documentation, doesn't provide better support, IMHO. On to your question...
No need to worry about any tunes for mod'ed bikes running lean. They are performance tunes and therefore richer than the factory tunes (esp at the high rpms/upper throttle positions). Just start w/ any of the non-SAI, aftermarket exhaust tunes in your VIN range and you'll be OK.
From the top of my desk to the bottom of your trashcan
superduty is offline   Reply With Quote
TORS tune from dealer or Tuneboy tune? Max_NYC Speed Triple Forum 25 07-06-2007 10:22 PM
anybody here using the tuneboy and if so what tune do you like king4456 Daytona Deliberations 9 04-10-2007 12:18 PM
TuneBoy tune questions RandyL Sprint Forum 1 05-07-2006 05:42 PM
Where to buy TUNEBOY?and how to tune? MarkTheBike Triumph SuperSports 1 03-28-2005 03:09 PM
