Motorcycle.com
Old 05-13-2008   #1 (permalink)
Favorite Bike: 2007 Speed Triple
Gearbox chatter
Hello All!
I have a newer (900 miles) '07 triple. Love the bike. Since about 200-300 miles or so, I have noticed what I think is gearbox chatter. It only happens above about 30mph regardless of gear or RPM. I cannot reproduce it by revving the engine at a stop. The chain is properly adjusted and I cannot find any loose or improperly adjusted things on the bike.
Any ideas?
Aesculapius is offline   Reply With Quote
Old 05-13-2008   #2 (permalink)
Favorite Bike: 07 Speed Triple
chatter with the clutch pulled in or not?
dePope is offline   Reply With Quote
Old 05-14-2008   #3 (permalink)
Bike isn't even NEARLY broken in yet. Chill.
My 2007 has 13,000 miles on it. It made various noises of varying levels for quite awhile that came and went randomly....now it purrrrs PERFECTLY. It's new so you are paying extra special attention to everything.
Make sure the oil is VERY fresh and not overfilled. Without typing a two page report, trust me, don't overfill the engine with oil. Not catastrophic, but speedy (1050) doesn't like it.
And somehow I would just GUESS you "adjusted" the chain while off the bike? hhmmmm? If so, this is incorrect. When gauging the slack in the chain you must be fully seated in the bike....when you are on the bike the chain tightens and THIS is the appropriate time to measure slack. SSSA bikes tend to prefer a SLIGHTLY looser chain so if you are eying it based on previous standard swingarm bikes....time to recalibrate your eye method.
S3Junkie is offline   Reply With Quote
Old 05-14-2008   #4 (permalink)
There is no chatter with the clutch pulled in, only with it out.
As far as the chain goes, it has never been adjusted. It still meets spec.
Old 05-14-2008   #5 (permalink)
Chev25250's Avatar
Chatter
Are you on the power or coming off it? & is it noticeable when you are slowing up & changing down thru the gears ?
Chev25250 is offline   Reply With Quote
Old 05-16-2008   #6 (permalink)
It seems fairly constant over a certain speed. When I power over that speed it starts, when I come off it stays until under that speed. I haven't noticed anything in the way of performance issues at all. The gear makes no difference.
Old 05-16-2008   #7 (permalink)
Favorite Bike: my one
Airbrush-Andy's Avatar
Other Motorcycle: Z1R
Extra Motorcycle: GSXR750Y sold
Try tubing the chain. Mine makes a noise when the chain dries out.
I do it at 40 P.S.I
Airbrush-Andy is offline   Reply With Quote
Old 05-17-2008   #8 (permalink)
ok new info. I was on a ride today and it only occurs when adding power in any gear above 30mph. Coming off the accelerator it goes away.
Old 05-18-2008   #9 (permalink)
Favorite Bike: 1050 S3
Have you whipped off the front sprocket cover to check the sprocket bolt?
avion is online now   Reply With Quote
Old 05-19-2008   #10 (permalink)
Smile Success!
Good news! It's Gone!
I changed the oil (since it was due) and also degreased/cleaned/oiled the chain. I went out for a quick test run and it's gone.
Thanks for all the help everyone!
Gearbox Chatter Problem Nunzio Speed Triple Forum 3 10-20-2007 11:40 AM
Clutch chatter Yelwoh The Rocket Science Forum 3 09-12-2007 06:17 PM
Clutch Chatter SbGunslinger Twins Talk 0 05-24-2006 09:06 PM
Clutch chatter farky Twins Talk 2 05-13-2006 01:42 AM
Clutch Chatter Odysseus Twins Talk 7 10-15-2005 01:07 PM
