» Log in
User Name Not a member yet?
Register Now!
Old 5 Days Ago
Newbie
Coolant Draining
HELP!
I have an 07 speed triple with 6K on the odometer. Recently ive seen coolant draining out of the down tube. So, I drained all the coolant, along with the brownish gunk in the resivoir tank. I ran water through the system till all I saw draining was water. Then filled it up with the appropriate coolant/water mixture. 1 minute after the bike is on, new coolant started to drain out of the drain tube...what the heck!? Can one of the hoses on the resevior tank be clogged or what? I got no $ to bring it to dealer, and rather fix it myslef anyway. ANY help would be greatly appreciated.
Thanks in advance
Old 5 Days Ago
speedy doesn't want to be too full. if you fill it to the high mark, it will spit it out. if it stops to spit when it's at the low, it's fine.
Old 5 Days Ago
sonnyboy11's Avatar
Speedy will belch out coolant until it reaches the level it likes. I know one guy who barely has anything in his fluid reservoir. You can practically consider it an 'overflow' reservoir. I'd let it do it's thing and leave it alone.
Old 5 Days Ago
Tricky's Avatar
Favorite Bike: speed triple 06
Although what the other guys are saying is true, when mine was doing this i got fed up after a few months and took it to the dealers only to find out on thorough check that my headgasket had gone causing back pressure to the cooling system, if you find that you are using oil aswell then this could be the problem also, good luck your dealer should take a look and it should not cost you any money as it is under warranty
It is not the size of the dog in the fight, but the size of the fight in the dog
Old 3 Days Ago
Newbie
Favorite Bike: 07 S3
Other Motorcycle: 06 CRF250X
I have an '07 that was doing the same thing. Turned out that the factory had the tube mis-routed and when it was supposed to go to the overflow, it was kicking it out on the ground. It's worth double-checking before you spend too much money.
Draining the motor oil gregp Hinckley Classic Triples 4 02-18-2008 11:28 PM
Draining The Tank Bonnebret Twins Technical Talk 6 09-11-2007 10:59 AM
radiator draining wookie Speed Triple Forum 23 04-30-2007 03:47 PM
draining coolant on s3. headlight wire meltdown Speed Triple Forum 4 06-23-2005 05:36 AM
Draining the tank offroad55 Tiger Workshop 2 04-17-2005 07:08 PM
