Motorcycle.com
Old 05-10-2008   #1 (permalink)
Favorite Bike: Speed Tripple
Other Motorcycle: Husquvarna TE 450
Extra Motorcycle: VOR 450
Rear Suspension Failure
Just bought a mint condition 06 speed tripple, been waiting quite a while to get one. Unfortunatly, took it out for the first ride and bottom suspension arm disintegrated . I am not a small bloke about 108 Kg (238 lb) but it should never have broken. Luckliy i was only doing about 25 mph over some speed control humps when it failed. Fortunatly, bike is still under warrenty so dealer is repairing.
Have found out that Triumph have had this link failed before and Hinkley have stated to me personally that the link is tested to well over 250 kg. As such, Hinkley have call for all of the rear suspension parts to be returned to them for testing.
Q. Has any body experianced this problem or heard of this problem?
Waders is offline   Reply With Quote
Old 05-10-2008   #2 (permalink)
Moderator
Favorite Bike: Blue 08 Tiger -Current
ruscook's Avatar
Other Motorcycle: White07 SpdTrple -crashed
Extra Motorcycle: Red 06 Sprint -Sold
Not on a speed triple I haven't. And I did 40000km in 13 months on my 07 with no problems.
It did happen on my 05/06 Sprint. Lucky me was one of the first in the world, 3 1/2 months later they did a worldwide recall.
The suspension is slightly different between the Sprint and Speedy so I wouldn't have expected this.
Good luck with your repair, and glad you weren't hurt.
Russ
ruscook is offline   Reply With Quote
Old 05-11-2008   #3 (permalink)
holy smoke! that lowest arm is metal(steel), how can that fail.? it looks very stong compared to other bikes, bikes like 636 has aluminium dog bones and even those can handle rear suspension usage.
jaket is offline   Reply With Quote
Old 05-12-2008   #4 (permalink)
Responce to Jaket: Link not steel on mine, Aluminium casting. Bottom section looks to thin around bearing race. See attached photo of busted link.
Bike still in dealers, hoping to get it back this week. Will keep you updated of Triumphs official responce.
Old 05-12-2008   #5 (permalink)
Favorite Bike: All of them
NinjaRAT's Avatar
Other Motorcycle: '07 Black Speed Triple
Extra Motorcycle: '06 Sunset Red Sprint ST
Correct me if I'm wrong, but wasn't there a recall on the '07 S3s for something like this? I recall bringing mine in on a recall notice, but then again, it might have been the bolt that passes through the lower dogbone and the shock.
As long as your speed limit is greater than your age, you're good to go!
My Gallery Old Gallery
http://www.danasoft.com/sig/BikeforLife.jpg
NinjaRAT is offline   Reply With Quote
Old 05-12-2008   #6 (permalink)
yes, the other link(lowest) in the pic is steel. the one that broke is aluminium.
I have to check mine.
EDIT: jep, my link looked fine, the loop is maybe ~4mm thick, also the part is cast aluminium and the seam of the cast is in the middle, actually at the point where that link broke. you can see the seam also in the upper edge of the link.
all the bikes weight comes over that link basicly, and because swing arm is long the forces are even greater than at the wheel axl.
JT
Old 05-14-2008   #7 (permalink)
Just got bike back from dealers. Must say they have done a fantastic job in repairing bike. Replaced every single part that was damaged including rear tyre. No hassle from them. Performance Triumph in Cheltenham, Glos, England.
Also checked out the 08 bike whilst i was there, the bottom link seems much beefer on them. I wonder why. Still waiting for official responce from triumph as to reason for failure. Will let you know outcome.
Old 05-14-2008   #8 (permalink)
Favorite Bike: The one I'm on 955 Speed
Other Motorcycle: KLR 600,VTR, W650,
Extra Motorcycle: BMW K1100RS,
Smile WoW
Thanks for the info. Please keep us informed. Glad to hear your dealer took good care of you and you were not hurt.
TRISPEED is offline   Reply With Quote
Old 05-14-2008   #9 (permalink)
Favorite Bike: '06 Speed Triple
Yikes. Did they replace it with an identical aluminum piece, or was it beefed up / a different material?
SafetyHelmet is offline   Reply With Quote
Old 05-14-2008   #10 (permalink)
Official Reason from Triumph: "Sir, would you kindly lose weight."
S3Junkie is offline   Reply With Quote
Rear Suspension GavS3 Speed Triple Forum 23 4 Weeks Ago 01:02 PM
Guy dies after rear wheel bearing failure :( TriSpri Sprint Forum 8 12-08-2006 06:15 PM
new st suspension failure HARTY Sprint Forum 10 10-04-2006 05:35 PM
Rear brake failure alert! viper3256 Sprint Forum 13 08-26-2005 04:40 AM
Rear Suspension motiztab Hinckley Classic Triples 0 07-04-2005 06:56 PM
