Old 05-10-2008   #1 (permalink)
Favorite Bike: 2007 Speed Triple
Bohdan's Avatar
Other Motorcycle: SV650
Installed: street triple flyscreen, carbon hugger and fatbar
Some time ago I have finished installation of basic accessories that I have procured through $1000 Triumph credit that came with purchase of my '07 Speedy. I took few pictures and think that some guys may benefit from my experience.
First I've installed the Street Triple flyscreen. Entire operation is relatively easy, but it is not straight bolt-on.
After removing rear cover from front panel (just pull it back, it is held only with two plastic posts inserted into rubber grommets) and the instrument cluster itself (one screw and another 2 posts into grommets + connector) you uncover mount plate. See picture below.
Flyscreen backplate mounts on top of this one, under the instrument cluster. It is held by 3 screws - threaded holes for these are visible on picture above to the left and below rectangular curout for connector and in the upper right corner, below big grommet.
There are 2 problems with this operation:
- backplate has lip at the bottom that goes against vertical post of mounting plate and prevents it from being flush with it. See picture below - backside of flyscreen plate (instrument panel inserted from the front, here below the plate): see lip/ridge at the bottom of it; next picture shows how it sits on top of post and make the whole plate stick out.
Solution is to cut the notch in this lip for the post, just enough for the plate to lay flush on metal mount (see pictures below -> in next post because of number of images limitation).
Bohdan is online now   Reply With Quote
Old 05-10-2008   #2 (permalink)
Bohdan's Avatar
- second problem: out of 3 holes for mounting screws only 2 line up with holes in backplate; one on the left side of connector cutout is too low. After a lot of deliberation I used only 2 screws - mount is strong enough, and trying to oval the other hole will just weaken plastic to point of flimsy hold. Picture above shows 2 screws used.
After fixing backplate I put the instrument panel back, secured with the screw and plugged connector. Flyscreen is fastened with 3 screws going into 3 holes in corners of the backplate and we're done.
Side view of mounted flyscreen below.
It is a little too forward for the '07 lights - both striple and '08 speedy have light domes more elongated, so it fits better (front of light/glass is about inch farther forward). Anyway I like this look - flyscreen seem to hover lightly attached above the lights.
Effectiveness? Good enough for me. It moved direct stream of air from my torso to upper chest/shoulder area, with diffused air touching below. Makes me comfortable to 90mph. I have the "visor" for flyscreen and hesitate to mount it - this is irreversible operation and visor covers most of the flyscreen painted surface, which I happen to like. Maybe I mount it later, or not - right now I don't seem to need it.
Mounting of the rear hugger posed no challenges. Things to look for:
- 4 holes for mounting screws are protected with plastic plugs. Three in front of the wheel are easily removed by prying them off. The forth one on the side of chain guard is long and with ribs that go into the threads; pry it a little and then remove "unscrewing" from the hole.
- you need 2 torx bits for screws T27 and TR30. Don't try to use hex bits.
Hugger bolts straight on. If you keep standard exhaust cans, hugger is pretty much invisible - might be better option to use plastic one ($125) instead of carbon fiber ($225).
Replacing handlebar is a little more time consuming. It is much better done with the help of friend - you need somebody to hold the bike when you tug on breaker bar (you need one).
In order to swap the bar:
- remove all controls on the left side. Rubber grip slides of when WD40 is injected through thin plastic straw underneath the rubber (thin screwdriver to lift it)
- right side is the same, put something there to hold brake fluid container and prevent spill.
- removal of the bar ends is easy - back-off the screw and tap on the screwdriver handle - this pushes the wedge out and lets easily remove bar ends.
- after unscrewing top of handlebar risers remove bar. Torx heads of holding screws are underneath the bar - do not try to use them to loosen risers, just for holding when you use breaker bar on nuts on underside of triple tree.
- inser breaker bar with the socket from the tank side, after turning steering head slightly away. Nuts are torqued very tightly, breaker bar and friend holding the bike (and screw head above triple tree) are necessary.
- on the right side it helps to remove clamp holding wires and move wires out of the way to have more space for breaker bar.
- After successfully removing risers use special risers for fatbar (separate accessory, does not come with the bar). Elongated top is towards the tank, so the leading edge of the bar does not cover adjusters at the top of fork tubes.
- special risers do not have screw+nut arrangement - screws go from the bottom into the threaded holes in risers. Put risers on top (don't forget fat washer) and tighten lightly. Put the fatbar into risers so they align; position of the fatbar is determined with the punch mark on the inside of the gap of right riser.
- Tighten riser screws from the bottom, attach riser top parts and fix the bar in place.
- put the controls back on. Use punch marks and holes for locating pins in controls.
Finished result below. I really like it - flat black instead of shiny bar, tapered aluminum, nice Triumph logo. Position is exactly the same as original. Just add Pazzos and its perfect (included in photo).
Old 05-10-2008   #3 (permalink)
Bohdan's Avatar
Installation - continued.
And one more picture of bar and finished bike.
Hope this might help somebody.
Cheers,
Bohdan
Old 05-10-2008   #4 (permalink)
Favorite Bike: what day is it?
SalsaShark's Avatar
looks nice... You've given me some ideas for my 07 green machine. I really like the blacked out top end. Me thinks that I need some of those pazzos. I was planning on powdercoating the upper tiple along w/ the rearsets and radiator shrouds next winter. I think I'll have to include the bar in that order as well.
www.cocsba.com
SalsaShark is offline   Reply With Quote
Old 05-10-2008   #5 (permalink)
Ferris's Avatar
Awesome looking bike dude. I do have one question for you though. Do the fat bars still use the stock bar ends?
Ferris is offline   Reply With Quote
Old 05-10-2008   #6 (permalink)
Bohdan's Avatar
Yep, all controls/barends fit exactly the same.
Old 05-12-2008   #7 (permalink)
very nice. i have the black fat bars ordered from my 03. now I know I have to use a breaker bar. thanks!
also have a hugger in that same order. i rolled up my license plate after mounting it under the seat. whoops!
me album
faffyface is offline   Reply With Quote
Old 05-12-2008   #8 (permalink)
scgstuff's Avatar
What mirrors are you using? Are those new stock mirrors? Can you see more than a pretty picture of your elbows?
Shawn
scgstuff is offline   Reply With Quote
Old 05-13-2008   #9 (permalink)
Bohdan's Avatar
These are stockers. I set it up as any mirrors on any other bike I've ridden: to see to left and right lane, and behind me when I shift to one side. Good enough for me.
Carbon Street Triple Straniero Street Triple Forum 7 12-19-2007 01:58 PM
Street triple with a speed triple flyscreen damasio Street Triple Forum 7 12-03-2007 07:23 PM
Installed Carbon FiberNew Hugger today RickyT Sprint Forum 2 09-16-2007 07:15 PM
1050 Speed Triple carbon fibre hugger and chain guard tokoloshgolem Modifications & Workshop Talk 1 07-12-2006 08:52 PM
Carbon Hugger - installed (pics!) - and other questions InParkSlope Sprint Forum 5 08-15-2005 08:11 AM
