» Log in
User Name Not a member yet?
Register Now!
Old 1 Week Ago
Favorite Bike: Speed triple
Send a message via AIM to steve214989
Secondary Air Injection SAI Blockoff Plates
While doing routine maintenance on my s3 1050 i noticed how large the SAI unit on the bike is. Also its located right in between both air intake snorkels to the airbox. Did some searching and cant find where I can buy the SAI blockoff plates. Looking at it I would have to think the SAI units positios has to be affecting airflow into the airbox. Even if its a minute amount I want it gone! Any help in finding them will be greatly appreciated. I also have the Arrow 3-1 race exhaust and access to get the non- SAI tune.
Old 6 Days Ago
Favorite Bike: Triumph 1050 Speed Triple
Bumped this thread cos I could do with some too. Bike running much sweeter now with Arrow map and the SAI blocked off at the airbox so think I'd like to just remove the whole lot.
Will probably run even better if my new K&N ever turns up.but that's another story.
Old 6 Days Ago
you can rotate the snorkels. so the other is facing up and the other is pointing more down, then the sai block thing is not it the way. or turn both down.
Old 5 Days Ago
I can give you guys the 3D files I used if you want to locate your own machinist.
www.myspace.com/beatpusher
Old 5 Days Ago
Favorite Bike: 2007 Speed Triple
Other Motorcycle: 1986 Honda XL250R
How much would an average machine shop cost to mill something like that?
Old 4 Days Ago
I paid $80... or something close to that. it's been awhile 8)
Old 4 Days Ago
NinjaRAT's Avatar
Favorite Bike: All of them
Other Motorcycle: '07 Black Speed Triple
Extra Motorcycle: '06 Sunset Red Sprint ST
Can someone give me the run-down on what removing the SAI would gain someone? I've done a bit of reearch, but am still not clear what purpose the SAI have and what removing would change.
As long as your speed limit is greater than your age, you're good to go!
My Gallery Old Gallery
http://www.danasoft.com/sig/BikeforLife.jpg
Old 4 Days Ago
No popping on overrun, cooler exhaust header, less clutter under tank during maintenance.
No performance benefit SAI or non-SAI.
Purpose of SAI is to burn uncombusted leftover fuel in exhaust header. SAI is just a simple solenoid that allows clean air to pass to exhaust header for this purpose. On most revs SAI is closed - open on closed/very small throttle openings only.
Burning fuel leftovers will aid in passing emission laws.
Old 4 Days Ago
NinjaRAT's Avatar
Ok, I think I had read that before, but forgot. Thanks for refreshing my memory.
Old 4 Days Ago
Note: Once unhooked you will most likely get a check engine light. This can easily be reset by a dealer.
Q: Secondary Air Injection beatpusher Speed Triple Forum 4 01-28-2008 03:08 PM
Secondary air injection Colin955Devon Daytona Deliberations 1 08-15-2007 10:03 PM
SAI blockoff plates, what gasket material? Martin_R Speed Triple Forum 9 11-12-2006 09:26 AM
Secondary plates MadRock The Rocket Science Forum 4 05-16-2006 07:53 AM
Secondary throttle plates? bigern2300 The Rocket Science Forum 3 10-04-2005 04:56 PM
