Originally Posted by 13
http://www.motorcyclecruiser.com/tec...cts/index.html
Don't Mix and Match: Never run two tires of differing construction. We can't stress this enough, and this rule applies to bias-plies vs. radials as well as tubeless and tube-type tires --even bias-ply vs. bias-belted tires. The results can be disastrous.
IMHO, that`s not entirely true. Partly, but not entirely. Many bikers will tell you the results are disatrous. Strangely, not many of them are able to tell you EXACTLY how, why or what will happen if you mix tyres.
I know plenty of road racers who deliberatly mix tyres to IMPROVE the handling of the bike. You need to know what you`re doing though and the results will vary depending on the bike. The general rule of thumb is that if you are mixing 2 different brands, ie a Michelin and a Pirelli, the front tyre must be the same compound or stickier. By far the best my Sprint ever handled was with a Michelin Pilot Power on the front and Bridgestone BT20 on the rear.
Different compound tyres from the same manufacturer with similar tread patterns can usually be mixed OK and then you don`t need to have the stickiest one on the front. One of the best setups I`ve had on the speedy is a standard Power on the front and a Power 2ct on the rear.
Like I said though, you need to know what you`re doing.
