Motorcycle.comBikeBanditTrident-Exhausts.comAdvanstarMotorcycleShows
BikeBandit
Old 04-02-2008   #11 (permalink)
Favorite Bike: whatever I got
gas_pig70's Avatar
Originally Posted by Night Train View Post
There is no monitoring charge for Lo Jack. Admittedly, it is expensive but worth the cost of being able to recover a vehicle and possible bust the thief.
I'll keep that in mind. For now I'm still looking for more info on the two alarms I inquired about.
'07 Speed Triple 1050 | '02 FZ1 (sold) | '01 DRZ400S (sold)
"'Course, don't ever tell anybody that they're not free 'cause then they're gonna get real busy killin' and maimin' to prove to you that they are." -George Hanson
gas_pig70 is offline   Reply With Quote
Old 04-02-2008   #12 (permalink)
Favorite Bike: 2006 Sprint ST
thinkjerm's Avatar
I don't know about the talon, but i know my scorpio paging alarm does not integrate into the stock alarm light and it does not allow you to disable the alarm unless you disconnect the power. I have called scorpio regarding deactiving the alarm if the fuse goes dead and they said i would have to disconnect the power and let the alarm go thru 3 cycles.
Some pro's about the scorpio is you can get it with the backup battery so if the motorcycle battery dies your alarm is still active, and you can get an ignition kill that will allow you to disable the ignition from the remote should someone steal the motorcycle.
thinkjerm is offline   Reply With Quote
Old 04-02-2008   #13 (permalink)
Originally Posted by gas_pig70 View Post
I'm trying to determine whether to get the Talon T3300 or the Scorpio SR-i600 alarms. For the most part the bike is part the bike will be parked in my carport or at work where crime is pretty low. I don't even lock my Jeep when the hardtop is on. The only reason I would consider the paging is for trips when I'm in a hotel room on a trip.
1. Does the SR-i600 utilize the factory alarm LED like the Talon system does?
2. Does either alarm allow deactivation by just turning the ignition key a set number of times like the factory alarm?
Going to be installing my SR-i900 tomorrow. It has auto-activate and de-activate via perimeter sensor and it came with ignition cut-off. As for your questions:
1. won't know til I install tomorrow -- user manual does not mention it
2. it has a feature that wil allow you to dis-arm the system after one cycle via turnsignal activation (1-left, 2-right, etc.)
Will post tomorrow when/if I get it installed.
Josey92 is offline   Reply With Quote
Old 04-05-2008   #14 (permalink)
did you get it installed - how did it go - looking to get an alarm for my tt600 soon!
later,
-d
boolean2 is offline   Reply With Quote
Old 04-05-2008   #15 (permalink)
Thumbs up Scorpio SR-i900
Install was easy with the Triumph Y-connector. If anyone is concerned about having to cut into wires, you only need to cut one in order to attach the ignition cut-off. It all work as advertised and it's loud. The most work is where to put everything in under the seat. You have the main module, the ignition kill, perimeter sensor, RFID antenna (sensor to arm/disarm alarm when the remote is within proximity) and all the wires. It fits but it takes up almost all the little space that was there.
One downside is that 2 of the connector clips popped right off when installing. That was offset by a very helpful tech support (Harley -- his name not the company) that immediately shipped out replacements on their dime.
Oh, it does not use the factory LED.
Total install time was appx half an hour tops.
Old 04-05-2008   #16 (permalink)
Awesome - Looks like I will be picking one up soon! Any pics?
Thanks!
Old 04-05-2008   #17 (permalink)
Thanks!
Will try to get them up this weekend.
Is the signalminder from New Bonneville plug-and-play? Ready to Ride Twins Technical Talk 34 04-24-2008 09:09 PM
Battery Tender & Power Plug Johnmala Sprint Forum 7 02-20-2008 12:58 PM
Plug and play alarms superfour Tiger Workshop 3 02-18-2008 06:23 PM
Brembos for 06 Speedy - plug & play scrannel Speed Triple Forum 34 06-12-2007 11:07 PM
Is Tuneboy plug and play yet??? Pig9r The Rocket Science Forum 10 12-05-2006 08:52 AM
