Old 03-02-2008   #1 (permalink)
under the airbox.....
i need to access the area underneath the gas tank and airbox. gas tank is off but airbox looks like a pain in the -ss. is there a way to get to that area without lifting the airbox. reason is the connectors to the turn signals are there and i want to change them
thanks.
iconrider is offline   Reply With Quote
Old 03-02-2008   #2 (permalink)
Dante's Avatar
No need to do that.. put your tank back on.
Just take of the transparent plastic from the blinker, unhook the wires, and pull them out, that's it.
regards!
D.
Dante is offline   Reply With Quote
Old 03-02-2008   #3 (permalink)
Thumbs up
gonna give it a shot....thanks....bought the watsen 10 led flush signals and thy're a quick install...just plug in and go but the plugs are under the f@$#ing airbox which takes an army to disassemble....anyway, thanks for the feedback.
Old 03-02-2008   #4 (permalink)
Dante's Avatar
OK, that s another thing, if you want to use the existing plugs to connect the turn signals.
Old 03-02-2008   #5 (permalink)
Hey do you know Legman?...he is a member here...he had a link to do exactly what i need...
death is easy......life is hard
Old 03-02-2008   #6 (permalink)
You might as well take your airbox off it's really easy, Undo all the Phillips heads screws pull the top off your box..( After you have disconnected all the hoses and sensors and taking note of how they go back on) Then just pull the bottom part of the airbox off easy. Now you know how to do it you can access your plugs and coils in case you need to, S3's are notorious for getting water down the plug wells and corroding plugs, If you can access your plugs you don't have to pay zillions of bucks for a shop to do it.
Stampy is offline   Reply With Quote
Old 03-03-2008   #7 (permalink)
Favorite Bike: My latest custom build
SKANK's Avatar
Other Motorcycle: 07 speed trip
Extra Motorcycle: 04 H-D roadglide
I forgot to mention to you in response to your other tread about the flush mount turn signals. Watsen LED's. They are set up nice and tidy with factory connectors and all but they screw it up by giving you those "little white bricks" to add resistance. I left mine off. It blinked too fast for my liking so I got a replacement flasher with resistor built in. Then I didn't have to jack with hiding and securing those included resistors. The aftermarket flasher/resistor replaces the stock under seat flasher and works as one plug in unit for all 4 signals instead of puting a separate resistor for each turn signal. Cost is less than 30 bucks. There's also a company that sells a plug-in flasher replacment that has a "you set" canceling function. It's pricy at 10 bucks.
IF IT HAS BOOBS OR WHEELS IT WILL GIVE YOU PROBLEMS.
SKANK is offline   Reply With Quote
Old 03-03-2008   #8 (permalink)
7Speedy3's Avatar
The gas tank is harder to take off than the airbox! Certainly harder to put back on. The airbox is a snap. Its a lot of bolts, but they're a piece of cake. Also, my Watsens had a resistor wire built in...
7Speedy3 is offline   Reply With Quote
Old 03-04-2008   #9 (permalink)
SKANK's Avatar
7speedy got the special ones. I got jipped....Again.
Old 03-04-2008   #10 (permalink)
Favorite Bike: Speed3 -09
No need to split airbox to remove it on 1050s. Undo two bolts at the rear af airbox and lift back of airbox up & towards seat. Installation is easy once you have seen what is under the box and how everything goes together.
Martin_R is online now   Reply With Quote
95 Airbox patrol21 Hinckley Classic Triples 6 01-05-2008 10:17 AM
Airbox apollyun Twins Technical Talk 1 09-26-2007 04:37 PM
07 airbox ttbonnie Twins Technical Talk 3 06-20-2007 07:57 AM
Look, ma..no Airbox! Ridge Twins Talk 24 11-24-2005 10:12 AM
airbox jefftarlton Sprint Forum 9 09-03-2004 04:15 AM
