S3 plug fouling problem - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!New BonnevilleMotorcycle.comHonda Powersports Ontario TourismSportbikeTrackGear
Old 02-24-2008, 02:07 AM   #1 (permalink)
Newbie
Favourite Bike: Speed Triple
Other Motorcycle: Ducati Hypermotard
Extra Motorcycle: R 1100RS, K 1200RS. R100R
I have about 4700 miles on a '06 S3. I am on my third set of plugs. The engine managenent system has been "updated" twice at the dealer. I just noticed some starting problems and looked at the current plugs, and they are fouled pretty bad. Has anyone else had this problem and have you fixed it? I am thinking about trying a one step hotter plug and maybe the NGK Iridium plug. Anybody tried this? The bike has Triumph off road mufflers and a K&N filter, but otherwise is stock.
augfal is offline   Reply With Quote
Old 02-24-2008, 12:15 PM   #2 (permalink)
Favourite Bike: Bonneville
Are they fouled with oil or carbon or what?
2005 Bonnie, Sleepers and Unifilter, AI gone, restrictor gone, Modre's peg kit, headlight & brake modulator, tach, NC wind deflector, gaiters, steibel, vmax mirrors, Hagons & Progressives, PIAA. http://TexasCoastGeology.com
geolpilot is offline   Reply With Quote
Old 02-25-2008, 12:06 AM   #3 (permalink)
Newbie
That might help to know, huh. They are wet. Basically, I was wanting to know if anyone else has had this problem with their S3 and what fixed it.
Old 02-25-2008, 12:55 AM   #4 (permalink)
Favourite Bike: Speed Triple 1050
Other Motorcycle: TTR 600 Yamaha Dirt bike
Extra Motorcycle: WR400 Yamaha
I'm no mechanic but I'll describe a plug problem(s) I encountered on my last S3 just in case it's relevant (now or in the future).
Bike progressively got harder to start particularly when hot. Injection cleaner additived seemed to help for a while. Then one time bike won't start at all. Trailered it to dealer, bike needed new plugs due to TWO simultaeneous problems (according to head mechanic).
1. Water in fuel tank, it got in there because the drain hole in rim under filler cap was blocked (apparently not unheard of). Everytime you open filler cap water goes into fuel
2. Plugs corroded on the OUTSIDE of engine. Apparently there are no drain holes to let water run away from plugs. Not a problem under normal use because because heat causes water to evaporate. But if you put the the bike away wet and cold the plugs will corrode on the outside, which means poor spark inside! (could possibly explain your wet plugs ??)
One last thing, you mentioned you've got the TORS (off road silencers) did you get the fuel injection map to suit? Not that I would know if not having it would cause any problem.
Good luck . It can only be something minor but I'm sure its quite frustrating
The clutch is the one on the left side...Isn't it?
My Photos
INTFIT is offline   Reply With Quote
Old 02-25-2008, 08:49 PM   #5 (permalink)
FL_Rat_Matt's Avatar
I had similar experiences.
Mine would occasionally be hard to start. After starting it would run on 2 cyls for a little and then clear out. Sometimes it would not start at all. So I had to take off the tank, the coil and wires and pull out the plugs and clean them, ( I have a plug cleaner, I have seen this on a lot of engines). After cleaning the plugs and putting them back in it would fire up just fine. I put an aftermarket pipe on, a 2 brothers single can, that actually solved the problem. It is my opinion that the cold starting enrichment is too rich, and at the right outside temp, the thing just floods.
I rode it for a while with the new pipe and no new map and it was very good. Just a little hiccup at 2500 that was all. So I was not going to remap. BUT, I went to the dealer for tires and front brakes and asked them to put the TOR map on it. I had to ride the bike 60 miles home. The bike ran worse then ever it was. she was really only happy cruising at 4000, anywhere else and I could hear it in the exhaust, it was not good. I was seriously upset. If anyone had rode the bike for me like I asked they wouold have known they messed up.
I parked the bike and bought a Tuneboy. 2 weeks later I put in map #20103 and the bike is absolutely perfect. I have never pulled out the plugs again, and I don't think I will have to until they are shot.
Bottom Line: Get the Tuneboy. The best money I spent on my bike by far.
HOG=Harley OWNERS Group
RAT=RIDERS Association of Triumph
FL_Rat_Matt is offline   Reply With Quote
Plug Fouling problems, need help augfal Maintenance & Workshop Talk 1 02-24-2008 01:42 PM
HELP One Plug Fouling! Michael A Twins Technical Talk 9 09-15-2007 08:49 PM
plug fouling on s4? brett_s Triumph SuperSports 4 07-19-2006 06:46 PM
Fouling plug, smoky exhaust t140 750 psds Classic, Vintage & Veteran 22 06-04-2006 10:27 AM
spark plug fouling problem '02 955i hollis Daytona Deliberations 6 03-27-2005 07:52 PM
