12000 service/bike not idling properly since - Triumph Forum: Triumph Rat Motorcycle Forums
Old 02-22-2008, 07:29 AM   #1 (permalink)
Just had the 12000 mile service my mechanic told me shims were out by alot there replaced also full service,since then my bike is not idling properly also when comming to a stop revs can drop to 1000 nearly cutting out bike only extra i have which was on the bike before service is carbon can exhaust i know the ecu controls the idling any help would be appreciated is there any way to manually set idling or is it just a case that it may just need to be run in again in regrads to the ecu
Tridolph is offline   Reply With Quote
Old 02-22-2008, 08:22 AM   #2 (permalink)
Favourite Bike: Speed3 -09
Martin_R's Avatar
It can be a bunch of things, but most fixes require a TuneBoy or dealer gameboy I'm afraid. Take it back to the shop and have them fix it.
After valve adjustment they are supposed to balance throttle bodies + reset idle stepper motor. They might have not done this or did it wrong.
On re-assembly they might have left one of the MAP sensor hoses unhooked or one of the hoses might be kinked.
Also while reassembling they might have installed camshafts 1 tooth off -> timing is off, resulting in rough idle and weak running.
Also as valve adjusting needs the removal & reinstall of camchain tensioner, the tensioner might not have clicked to a tight enough setting yet -> camchain is slapping a bit -> timing wanders -> rough running. After I did the valve adjustment on my 1050 I had to manually push the tensioner one click further to stop the camchain slapping around. Symptoms were quite close to what you described.
Martin_R is online now   Reply With Quote
Old 02-22-2008, 12:38 PM   #3 (permalink)
oldndumb's Avatar
Ditto wot Martin said. There is a set procedure that must be followed when reinstalling the tensioner. There is more to it than just putting it back in place.
Oldndumb
Caveat lector
oldndumb is online now   Reply With Quote
Old 02-22-2008, 08:21 PM   #4 (permalink)
thxs for help will try to get to a triumph main dealer here in ireland my nearest dealer is 120 miles away
$500 for the 12000 mi Service???!!!!! Nightwatchman Twins Technical Talk 28 08-05-2006 08:21 AM
12000 mile service hinkleyboy Triumph SuperSports 15 06-24-2006 02:40 PM
12000 mile service Mullethead Daytona Deliberations 6 05-05-2006 10:09 AM
12000 MILE SERVICE ColinHitchcock Triumph SuperSports 5 03-22-2006 06:41 PM
12000 mile service CATUCK Tiger Chat 7 12-20-2005 06:41 AM
