» Log in
User Name Not a member yet?
Register Now!
  #131 (permalink)
Old 09-20-2007
This problem sounds more like regulator/rectifier failure. These are a more common point of failure within a bike's battery charging system. It would be worth checking the output voltage from the rectifier - should be circa 13-15V at ~4500rpm?
Unfortunatly I don't know which wires they will be on an '03 S3; but hopefully someone will be along with an answer shortly...
Good luck.
  #132 (permalink)
Old 09-20-2007
Benearlong?'s Avatar
Newbie
Favorite Bike: Speed Triple 1050
Originally Posted by WillyBRollin View Post
I have a 07 s3 and the suspension is squishy as hell. I tried adjusting the compression and tension settings but not mutch came of it. Also the way it works is like no other bike iv seen there is tension on the left fork and compression on the right fork. are the older models setup like this? and How is it physicly possible to change the settings of both forks while only ajusting one side?
I have the same "problems" with the suspension on my 07 S3 (few months old).
Did a trackday last friday and tried to adjust the suspension with the help of some experts. The adjustments improved the suspension a little but not enough! At the end of my trackday we concluded it needs stiffer springs (front and back) and thicker oil (front). So, in a few weeks my S3 has the suspension-quality of a superbike!!
"Hiyageorge. Lobuddy. Benearlong? Cuplours."
  #133 (permalink)
Old 09-20-2007
ruscook's Avatar
Favorite Bike: Blue 08 Tiger
Other Motorcycle: White 07 Speed Triple
Extra Motorcycle: Red 06 Sprint
Weird, my S3 had virtually NO preload on the rear so I couldn't get any decent suspension settings. Now I have some preload I've been able to dail in the damping a lot more and it's less harsh but still not "squishy" and I'm about 125kg with gear.
Russ
  #134 (permalink)
Old 10-22-2007
Favorite Bike: 2007 S3
Other Motorcycle: Cb350
Left front brake rotor is discolored. It is a greyish color. On the freeway, going to work, had some chatter from the left caliper. Anyone had something like this happen? There is not really any change in the braking power or lever travel.
Zip
"You don't know what you don't know."
  #135 (permalink)
Old 01-10-2008
Newbie
I purchased a 2006 1050 new in march 2006 i ride it to work everyday and wheely just about all the time it gets covered in crud constantly but the finish is holding up well i`ve replaced the fork seals myself and added 10w oil which is thicker and the forks are much firmer.The battery terminals kept coming loose so i fitted spring washers i had the clock assembly replaced under warranty at 4000 miles as they went kaput i fitted a k n airfilter but notice no real power increase i wanna do a single sided gp style exhaust mod but dont know what to do with the O2 sensor i`ve had no brake issues but i fitted better quality pads anyway i also notice i have a gap at the back of my seat where i notice all others sit down nice and tight to the bodywork i`m on my third set of tyres at 11000 miles but i do abuse em i love the bike and find it comfy and agile could use a bit more power tho...the dealer where i bought it has since gone skint so i now have to find another dealer for servicing and warranty issues BUT its still better than most other bikes i`ve had and that is a lot of abused bikes RIDE ON TRUMPERS
  #136 (permalink)
Old 01-10-2008
Favorite Bike: ducati
problems
my 06 the battery cables kept comming loose, 200miles 1000,miles and 3K locktight worked so far.
other problem also stupid grin!
Oh yea slight chug at 4K RPM noticed more scince the M3 exhaust only at light cruz. Anyone else? has been remapped at dealer but did not make a difference.
  #137 (permalink)
Old 01-29-2008
Newbie
my whinge
G,day all. My only real complaint with my 07 speed triple is that they seem to run HOT! Now everyone I speak to says that's normal, but it can't be right that the thermo fan kicks in when the temp is 10oC sitting at a set of lights! My only worry is should the fan fail for any reason, and it's a hot day, I guess you're in for a long walk home. As an added aside, I see clutch cables seem to be a bit of a problem. Are they breaking where the cable comes out of it's guide down near the clutch cover. Mine was rubbing there but a bit of modification and the cable runs in the centre of the guide. So far so good, but it has only done 10000km's so see how we go.
  #138 (permalink)
Old 02-19-2008
DGA's Avatar
DGA DGA is offline
I have an '07 1050 and the clutch cable is already showing rust on the exposed parts of the cable. Is this normal? I got a spare one just in case.
My instrument cluster is also not watertight. There is condensation and water on the inside. Still works though.
  #139 (permalink)
Old 4 Weeks Ago
Originally Posted by nakedlover View Post
I have an older (03) 955 and the speedo
doesn't work at all on cold days. i have to
warm up bike, turn it off, then back on
again and it usually fixes the problem.
My '03 Sprint does that... I've been told it's an indication of low voltage @ start-up & that it takes a "Heat" Cycle to reset. Replaced my Battery and it quit doing it. I've also heard that there is an updated tune that remedies that
Cheers y'all, Cyn-
First you take the test,
then you learn the lesson!
Members Album
  #140 (permalink)
Old 4 Weeks Ago
DEcosse's Avatar
Moderator Note - I just did a housekeeping clean-up of this thread - removed a lot of posts that were just chat - nothing really wrong with them, but wanted to sanitize the thread down to just the posts containing information constrained to the sticky subject since this is a reference thread - i.e. common S3 Issues.
Thanks for understanding if your post got deleted.
GSXR 1000 Front End Swap
British Entertainment - Is this Common? Ridge Biker Hang-Out 28 02-14-2007 03:32 AM
Help with common acronyms rstover Triumph Twins HangOut 10 02-07-2007 09:21 PM
Common problems? Kirk Triumph SuperSports 3 06-13-2006 02:31 PM
Common Speedmaster Binnsy Triumph Twins HangOut 8 02-01-2006 09:18 PM
Common performance upgrades? Triumph SuperSports 2 05-03-2005 10:37 AM
