Firstly, the S3 is fantastic, I have a T509, drool over the 1050
Problems so far;
Battery drain over 2-3 days, traced to incorrect relay installed in lighting circuit.
Earth / return common block melt down, causing intermittent engine management warning light and lights turning themselves off momentarily. New block / re terminated wires.
Coolant in oil after a hugh back-fire on start-up. Engine drained, cleaned and check all OK, but now happened twice in a year. Suspect liners lifting and letting by if bike back-fires. - ongoing
Speedo cable broke at wheel end, replaced with new, now speedo threaded cable connection broke, awaiting new speedo!
BUT STILL LOVE THE S3!
