If your lip hits the brake reservoir simply adjust the angle of your handlebar mounted brake assembly,then adjust clutch side to match.Laminar offers at no charge heavy-duty plastic type velcro mount system that is superior to the double sided tape and allows for fine adjustments and east on/off.I am 6'4" tall and I must sit bolt upright or tuck in to reduce helmet buffeting at high speed.Short folks should be OK with it.
