» Log in
User Name Not a member yet?
Register Now!
  #11 (permalink)
Old 12-08-2007
Blindboypig's Avatar
Favorite Bike: Triumph Speed Triple
Other Motorcycle: Aprilia Falco
Extra Motorcycle: Triumph Thruxton
"The adjustment on the forks for compression and rebound are on different forks such as they've done with the new kwaka Z1000. This they did to keep the cost down I'm guessing."
This is done on several full-race machines - not at all a cost-cutting feature. Just due to frame/fork rigidity plus makes tuning a bunch easier (no more "off a click on the right"). Duc's doing this on the nearly $75,000 D16 so I doubt it has anything to do with cost at all.
The S3 is a great all-rounder - makes the right sounds, pretty decent handling, and absolutely gnarly in all respects. Even decent as a light-tourer (600 miles a day, no problems). Wheelies and power slides have never looked so good
  #12 (permalink)
Old 12-10-2007
Favorite Bike: all of them
Other Motorcycle: Thruxton, spd Triple
Extra Motorcycle: T140, BSA B50
good and bad
good = great looks, great sound (with TORS), OH that power!!!
very good build quality, good riding positon (and I'm almost 60)
Bad= that silly rear "fender" thingy, no rear inner fender or hugger
OH that power
  #13 (permalink)
Old 12-12-2007
So what is the mpg on one of those? Speed is nice (very nice!), but I have to be able to afford riding every day.
  #14 (permalink)
Old 12-12-2007
HiVel's Avatar
the shorty exhaust looks kinda funky but if it works go for it!
Hope your femur heals -that is a bummer! While you are laid up and can't ride maybe you could paint that green monster a nice color?? (just kidding) Get well soon!
Anything worth doing is worth doing to excess!
2007 Tiger "Old Blue"
  #15 (permalink)
Old 12-12-2007
DGA's Avatar
DGA DGA is offline
Pros: Tons of power, engine attached to wheels and some controls look, great fit and finish, comfortable for longer rides, handles great, sounds awesome, gets tons of looks.
Cons: The seat does not allow you to move around that much, so finding a comfortable spot to hang off the bike can be tricky. Low fuel light not worth a dam. Sometimes the engine sounds like it want to ping itself to death, only sometimes though. Clunky gear box. Soft clear coat on the gas tank scuffs easily, but I hear that the clear coat is thick though, making it easy to buff out.
  #16 (permalink)
Old 12-13-2007
is pillion comfort as non-existent as it looks?
  #17 (permalink)
Old 01-04-2008
Newbie
How Much for that exhaust?
Originally Posted by ken226 View Post
Not certain about the 05-06 by my 07 responded very well to a better flowing exhaust. I bought an Akrapovic Titanium Megaphone thats made for an 06-07 R6, fabracated a connector pipe and the results were amazing. I removed everything from the right footpeg back and installed the megaphone with in the typical Moto-GP style location. I couldn't get in on the Dyno, Arizona Victory couldn't figure out how to put it on the Dyno without a spark plug wire to connect to. Seat of the pants improvement is obvious though, with bottom end torque being the most obvious improvement.
With the stock exhaust, when I snapped the throttle open quickly the front end came up at about 3/4 throttle, now its up at less than half. Midrange is definitely better and top end feels close to the same. Strange, you'd expect a pipe like the Akrapovic Megaphone would make mostly top end, but I swear it feels like the biggest gain was 3-6000 rpm, with smaller gains everywhere else too.
Oh, forgot to add that its LOUD. Not so bad at low load, low rpm but when you twist the throttle its almost as loud as a Harley.
I was just curious on what that system costs? I have an arrow system. Its alright.
Thanks
Michael
  #18 (permalink)
Old 01-06-2008
ken226's Avatar
Favorite Bike: 2007 Speed Triple
Other Motorcycle: 1991 CR500
Extra Motorcycle: 2003 620ie Monster
It costed about 180.00 shipped, but I had to fabricate a connector pipe using 1 3/4 inch exhaust tubing, and a bracket. The pipe is actually designed for an 06+ R6.
http://cgi.ebay.com/ebaymotors/New-A...spagenameZWD1V
  #19 (permalink)
Old 01-07-2008
heat shield/radiator spacer
while rolling my 07 s3 1050 off my trailer... it was wet.. slipped and dumped it on the trailer ramp.. then noticed coolant running down... looked at the side that it landed on and saw that both spacers connected to the heat shield had punched into the radiator and broken free... ie new radiator.. found out it is manufactured by ktm... what was interesting is that the radiators were back ordered out of atlanta (main distribution center for usa) which leaves me to think that others may of had a problem... after a wait and $ 750 had a new radiator... also took the old one to the local radiator repair and had it repaired (braised) for $25 as a back up.
  #20 (permalink)
Old 01-08-2008
Favorite Bike: Speed Triple 1050
Other Motorcycle: TTR 600 Yamaha Dirt bike
Extra Motorcycle: WR400 Yamaha
Good...Wide handlebars
The wide high dirtbike style handlebars are great (maybe except for very high speed because you catch more wind). So much easier to manouvre around parking lots, do u turns etc. than a bike with clipons. I love them on tight bumpy rough real world roads because its much easier to maintain a higher degree of control IMHO than true sports bikes that are designed for more race track conditions.
While the exact shape, angle and positioning of the bars is a matter of personal preferance you can go to the local dirt bike shop if you want to do a bit of fine tuning to the riding position. Though if you go higher you may need a longer brake line.
The clutch is the one on the left side...Isn't it?
My Photos
Speed Four to Speed triple, good choice? Reppyboyo Speed Triple Forum 14 10-27-2007 10:37 AM
Street Triple Demo Ride - The good and the bad rorider Street Triple Forum 14 10-11-2007 12:05 AM
My 1050 Speed Triple is making way for a........... robnobrakes Speed Triple Forum 6 07-20-2006 04:25 AM
I have just ordered a 1050 Speed Triple robnobrakes Speed Triple Forum 4 08-18-2005 07:25 AM
1050 speed triple geordiesas Speed Triple Forum 0 07-16-2005 02:27 AM
