Old 01-16-2005   #1 (permalink)
Just purchased a fly screen for my '01. Its the screen with the bubble as pictured here. Waiting for it in the mail. I will probably have to hunt around for some hardware for it as it was an ebay buy. I imagine it's a pretty straightforward install but would like to get feed back from anyone who has done one concerning:
-what hardware works best.
-any install quirks
-problems I might avoid
-tips/tricks
Also putting a cowl on. I boughtt a black colormatched shell brand new from a dealer(no inards) and another complete cowl on ebay that was the wrong color but had the inards. I'm just going to swap out the inards to the black one. I'm going to need to buy hardware (screws) for this one to as the stuff they used was obviously not correct and they didn't even have screws in all the attactment points. Hardware suggestion would be great.
Thanks,
Lee
ezlee is offline   Reply With Quote
Old 01-16-2005   #2 (permalink)
-any install quirks
-tips/tricks
Thanks,
Lee
Old 01-19-2005   #3 (permalink)
The flyscreen mounts to the back of your speedo/meters using existing hardware. Hopefully, You should not need anything different. Worst case, you'll need the same screws that are 5mm longer is all. I'd purchase some blue locktite as it is humanly impossible to tighten the third mounting screw. (brilliant design).
The seat cowl only attaches to the hardware with plastic screws (they look amazingly just like wood screws). I can't imagine you'd need anything that special to make that work.
To make my seat cowl fit the bike better, I purchased a few washers and shimmed the latch on the sub-frame. My (and my buddies) seat cowl would contact the rear fender. Putthing the washer under the latch made it play nice.
I also used my trusty dremel to cut out the center of the black plastic undertray of the seat cowl so I have a much greater storage capacity.
Fret not, padawon learner, install is easy-cheesy-japaneesy
dp
Canyon Chasers Sport Touring
http://www.canyonchasers.net/
CanyonChaser is offline   Reply With Quote
Old 01-19-2005   #4 (permalink)
Yup Yup,
The seat cowl install is a you said pretty straigthforward. Great idea dremmelling the seat cowl pan. Too bad the "engineers" at triumph didn't come up that one and constrruct a purpose built cowl pan that receeds for more storage. It only makes sense that if you are losing the seat you should get more storage as there's really nothing going on in there to prevent it. To be honest I was surprised when I fitted the component and found no more storage space than with the stock pillion.
The only other thing I may do is fit son rubber grommets to keep those button-head screws from scratching the paint on the cowl.
Fly Screen,
Asked about this because the fellow I purchased it from said there is supposed to be a spacer included that I will not be getting. We'll give a try and see what happens.
Cheers and feel to relay any further tips.
Lee
[ This message was edited by: ezlee on 2005-02-01 11:25 ]
Old 02-01-2005   #5 (permalink)
Finally put my cowl on. Ending up using size 6 3/4" sheet metal screws butted against a rubber washer to protect the paint and plastic screwcovers to hide the silver screws and smooth over and sharp edges. Comes out looking like this
Under the covers . . .
Washers to shim the seat latch make this function as it should.
Everything still fits flush
Lee
[ This message was edited by: ezlee on 2005-02-01 11:42 ]
Old 02-02-2005   #6 (permalink)
nyburner's Avatar
What color is the extra seat cowl shell you have? Would you be willing to sell it? Thanks.
nyburner is offline   Reply With Quote
Old 02-02-2005   #7 (permalink)
nyburner's Avatar
Old 02-02-2005   #8 (permalink)
Its silver from a 2000 Daytona. Anyone interested in the extra shell pm as the forum is probably an inappropriate place to discuss buyin, selling, etc.
Lee
Old 02-02-2005   #9 (permalink)
Lee
Old 02-02-2005   #10 (permalink)
Got a bad case of ebay photoshow going in that 'flush' pic there ezlee. Good thing you weren't naked like the original bloke, lol.
tail bag AND seat cowl ? XavyBaby13 Speed Triple Forum 6 08-10-2007 10:31 AM
tyhinking of solo seat/cowl and no more flyscreen-few ??? rickj Hinckley Classic Triples 14 07-01-2007 11:14 AM
Dart Flyscreen (NB) vs National Cycle Flyscreen (Bella) dawgfan Twins Technical Talk 19 07-11-2006 11:22 AM
Hard Tail or Soft Tail for New Bonneville MaxH Modifications & Workshop Talk 11 04-29-2005 09:49 AM
Speaking of K&N Istallation...... GrendelPrime Speed Triple Forum 8 03-05-2005 08:36 AM
