Old 11-04-2007   #1 (permalink)
full exhaust system question
For those of you who fitted a complete exhaust- not slip on etc- is there anything you need - exhaust manifold gaskets etc- or is everything there/ reusable?
Thanks- Steve
ds tiger is offline   Reply With Quote
Old 11-04-2007   #2 (permalink)
you should get some copper exhaust gaskets, some sealer for the slip on joints if there are any.
also you will need some pb blaster or comparable thread loosener if youve got more than a few hours on the bike, get all the oil cooler braket bolts and the header nuts.
antiseize for reassembling same
watch for pipes rubbing together if it is a multi piece header, on the zard the pipes can rub holes in each other if not mounted carefully.
you dont need to break any oil or radiator lines loose just let the cooler hang and the radiator will flex enough.
its a good time to replace the coolant though
HURT SMURT !!!
ctrhenry is offline   Reply With Quote
Anyone tried the Bub 2-2 Full Exhaust System on a Scramber? scolepdx Twins Talk 20 03-02-2008 10:17 PM
full system jimmie Speed Triple Forum 1 03-30-2007 08:43 AM
Aftermarket full exhaust question moddedtunnel Twins Technical Talk 2 11-30-2006 08:10 PM
Is Zard the only full exhaust system? TightTL Speed Triple Forum 3 08-19-2006 09:13 PM
Full Exhaust System? Tiger Chat 2 07-29-2004 03:11 AM
