Old 01-10-2005   #1 (permalink)
Anyone used it?
any tips on applying?
Got some gold on the way.
Cheers Mark.
rictus01 is offline   Reply With Quote
Old 01-10-2005   #2 (permalink)
Can you give some details perhaps maybe a link ?
SlvrSurfr is offline   Reply With Quote
Old 01-10-2005   #3 (permalink)
Just done a quick goggle search,
here's a link to the product (but not the company)
Caliper paint
I got mine of Ebay for £8 ($15 usd), , secondhand but never even out of the box, bit of a bargin after seeing the price of the stuff.
Cheers Mark.
[ This message was edited by: rictus01 on 2005-01-10 22:52 ]
Old 01-11-2005   #4 (permalink)
Why didn't you go with red paint?
2000 TBS Cafe Racer :: 2000 Frankenmille
TBSstunta is offline   Reply With Quote
Old 01-11-2005   #5 (permalink)
I've got red spokes and the callipers would have been lost with their colour, also I have a gold clock surround and brake res cap so it will complement them nicely.
Cheers Mark.
Old 01-14-2005   #6 (permalink)
check out some of the forums for honda (ricer upgrades) or mbworld.org (mercedes). These are pretty popular with both of those crowds. The only things I remember are: 1) use abundant quantities of brake cleaner. Wipe and respray, wipe and respray. You cannot get the calipers clean enough. 2) if you can, take the calipers off the bike to paint and prep (not in that order of course), 3) mask off any vitals! 4) mask off the lettering before painting - makes it look pro instead of ricer, 5) be ready to work fairly quickly. This isn't paint - it's a 2 part epoxy that starts hardening when you mix it. 6) if you screw up an area and it's set a bit already - DO NOT futz with it. You'll end up making it worse. Let it dry, sand lightly and reapply or ignore.
Hope this helps. Post some pix when you're done with closeups!
P
Old 01-14-2005   #7 (permalink)
P
Old 01-15-2005   #8 (permalink)
P
Thanks peeti, just a couple of things, the instructions say to mix it and leave it 10 minutes before applying ?
Also I was going to paint over the lettering, then on the finest belt linish the letters down and apply a bit of clear lacquer over them ?
Cheers Mark.
Old 01-15-2005   #9 (permalink)
P
Cheers Mark.
Old 01-16-2005   #10 (permalink)
'linish' ??
Queen's english sure is strange
On a serious note, if you mean coat and sand/file then yes that should work. Be very careful on the surrounding paint. It should be infinitely easier to go this route than masking. I can't picture the calipers at the moment, but if the lettering is raised, then this should be a piece of cake. If depressed/debossed then mask away - scraping the insides stinks!
As far as the waiting period - I can't speak to that. Never did it - the info I posted was from the things I've read over the past couple of years on the other sites.
Good luck!
p
Brake caliper rebuild. AVM Tiger Workshop 7 02-13-2008 01:43 PM
Brake Caliper HKTon-Up Club Cafe 22 02-01-2006 06:57 AM
Rear brake caliper TrumpetST Sprint Forum 1 08-24-2005 12:36 PM
Brake Caliper Help needed TTsprint T3 Sport / Touring Forum 4 08-16-2005 07:20 PM
brake caliper triumphtimes Sprint Forum 3 02-08-2005 07:30 PM
