Strange LCD display issue
Searched the other threads and couldn't find another situation like mine, so I thought I'd see if anyone has any ideas.
My problem is that the display sometimes flickers on my '03 Speed Triple. The problem started a couple days ago and might happen sporadically 2 or 3 times every 10 miles or so. It looks as if the bike had just been switched on. You see the display go off for a second and then come back on and run through the startup things like the speed being "188", the temp being "Lo". The tach dives when this happens too. The time and odometer are not reset though, so I don't think it's completely losing power.
I ran through the typical things like checking the ground to the battery and so forth. I don't think that's the issue since the bike seems to perform fine while this is happening. I found another thread that said display issues can be a loose wire. That still may be the case, but I can shake all the wires behind the dash and jiggle the wire harness all the way to the battery and cannot reproduce the issue. Usually it only happens when I ride. But just now, with the bike parked on the side-stand and the bike in neutral, I got the display to do this running the tach past 5K. Maybe a vibration thing?
Any help would be appreciated.
