Old 10-29-2007   #1 (permalink)
losangeles_S4's Avatar
Tool for Front Axle Removal
What size allen do I need to remove the front wheel?
So retarded that this stuff is not included in the tool kit.
2002 S3 waiting for new rubbers to be installed.
Best,
Erik Hillard
2002 Triumph Speed Triple
1976 BMW R90
losangeles_S4 is offline   Reply With Quote
Old 10-29-2007   #2 (permalink)
22mm allen.
I got mine from www.snapon.com that fits onto a wrench
I just saw one in a local cycle supply store that had multiple sizes on one piece.
dblhelx is offline   Reply With Quote
Old 10-29-2007   #3 (permalink)
Thanks.. greatly appreciated.
Best,
Erik Hillard
1976 BMW R90
Old 10-30-2007   #4 (permalink)
Or, if you want to go the truly cheap b route:
(1) go to hardware store
(2) find a nut that measures 22mm across
(3) find a bolt to fit that nut
(4) weld nut to bolt
(5) new "tool" can be used with a standard socket set
Total cost: <$1
One day I got pulled over for speeding. The cop said, "don't you know the speed limit is 55 miles per hour?" I said, "yeah, I know...but I wasn't going to be out that long." - Steven Wright
Eldercanuck is offline   Reply With Quote
Old 10-30-2007   #5 (permalink)
I use a 13/16th's craftsman spark plug socket turned around backwards. The hex fits in perfectly then use a regular ratchet with an extension to turn the plug wrench from the other side. Not sure if that size is the same for the older S3s though.
Mike
bikeman is offline   Reply With Quote
Old 10-30-2007   #6 (permalink)
1050 axle is 22mm (close enough to 13/16 that that trick works) but the previous bikes are smaller. Not sure but I think 18 mm? I just use a piece of stainless steel 22 mm hex stock that we use to make oxygen sensor shells at work. I guess not everybody has chunks of that laying around?
dr_gallup is offline   Reply With Quote
Old 10-30-2007   #7 (permalink)
Have an 02 S3
Copied from the S3 FAQ above, but worth repeating...
02 S3 takes a 17mm bolt, not a 22mm. Motion Pro makes a handy 4 in 1 axle tool that has the common hex sizes (17, 19, 22, 24mm). Only the cro-moly version has 4 sizes, the aluminum does not have the 17mm size. www.motionpro.com. Does the job for Speedy and my FJR.
v3rp is offline   Reply With Quote
Old 10-30-2007   #8 (permalink)
Awesome! Thanks! Sears told me today the biggest they had was 17mm.. so thats great news now!!
Best,
Erik Hillard
1976 BMW R90
Old 10-30-2007   #9 (permalink)
Hi Eric - I bought mine at
Sears - Don't remember what I paid, but at least it wasn't outrageous. That Sargent seat still holding up for ya?
Mark G
SP3inAZ is offline   Reply With Quote
Old 11-01-2007   #10 (permalink)
Wrench was $9 at Sears. The seat is great.
Best,
Erik Hillard
1976 BMW R90
Front Wheel Removal Tool dblhelx Speed Triple Forum 1 09-27-2007 09:35 PM
Small adapter tool for removing front axle unummyu Sprint Forum 5 07-02-2007 04:43 PM
2000 TT 600 front axle tool size? OhiomaleCop Triumph SuperSports 4 06-23-2006 12:40 AM
'05 front axle removal dgilmore Speed Triple Forum 3 10-15-2005 03:55 PM
Front Axle Bolt Removal Please Help Kngelv Sprint Forum 3 03-29-2005 06:53 PM
