There was/is a factory recall for the fuel connectors, but the replacement ones triumph supply fix only half the problem. If you go to
www.rideteamtriumph.com, you can purchase the complete metal fittings for about 70 bucks. I replaced mine and it was an easy job. Also, if you do a search on here or at T595.net, you will find a lot of instruction on how to replace them.
