Agreed Aggy, going down one tooth on the front is the best and easiest, no change to the chain length, just keep it lubed and all is well.
If you like hoisting the front wheel, it's a snack with the lower gearing and you can still cruise at 120kph in 6th at less than 5,000rpm.
Have a happy New Year!
Mick
