Motorcycle.comTrident-Exhausts.comAdvanstarMotorcycleShowsBikeBandit
BikeBandit
Old 09-19-2007   #1 (permalink)
Ferris's Avatar
LED Flasher Option
After purchasing the "Clear Alternatives" taillight, I decided to get the LED flasher from newspeed3.com only to have it fail after 2 weeks. It still worked but it started clicking as soon as I switched on the ignition. I visited my local sparky and he replaced it with a 2 pin “Tridon HD12”. This unit is definitely better quality and was a ****load cheaper at $15NZD (approx $11US).
I’m also using stock front indicators!
Ferris is offline   Reply With Quote
LED flasher unit trouble ? Help pls wispspeed Speed Triple Forum 9 06-19-2007 09:11 PM
LED Indicators / Flasher Unit Blackjack Twins Technical Talk 1 03-12-2007 09:16 AM
gsxr footrest and LED license plate LED brake light installed MotoRaider Speed Triple Forum 19 01-23-2007 09:13 PM
LED Blinkers & Trick Flasher GrahamC Speed Triple Forum 5 07-04-2006 10:47 AM
LED/Low wattage indicator flasher rate fix--sorta FelixLeiter Speed Triple Forum 3 04-27-2006 05:34 PM
