BikeBanditAdvanstarMotorcycleShowsTrident-Exhausts.com
ShopTriumph.com
Old 09-17-2007   #1 (permalink)
Electrical connectors
I have posted this on two other Triumph sites with no luck. I bought a tail kit from e-bay, top shelf quality but the brake lite supplied does'nt have a connector that mates with the stock Triumph piece from the harness. Does anybody know where to get the three pin connector, (both ends) for the stock Triumph brake/running lite. I dont think the existing one is reuseable. itchin. BTW, it's an 06 S3.
And you KNOW this.........MAAANNN.
itchin is offline   Reply With Quote
Old 09-17-2007   #2 (permalink)
Why not cut the stock connector off of the stock brake light aseembly, with as much of the old wire as you can snip off, and then splice that piece into the new tail light so it plugs in the right way.
dblhelx is offline   Reply With Quote
Old 09-17-2007   #3 (permalink)
If you don't want to cut the stock harness I'm sure if you stop by Radio Shack you can find some single connectors to plug into the stock harness.
Whirlwind is offline   Reply With Quote
Old 09-17-2007   #4 (permalink)
I mean you are going to throw away, or not use, the stock break light anyways....so might as well cut the plug off of it. Splice it into the NEW brake late instead of it's plug and reattach it with some high quality connectors or quick solder and shrink wrap it....takes all of 5 minutes with a $10 solder gun and 14 cents in shrink wrap and you'll have it for the next time...and there will be a next time.
Old 09-17-2007   #5 (permalink)
Other Motorcycle: 06 Speed Four
Extra Motorcycle: Vespas/Lambrettas
however those triumph connectors are really really nice . totally regret cutting mine off for my kit . I kept them though , maybe one day...just maybe ,I'll figure out how to re-use them
XavyBaby13 is offline   Reply With Quote
Old 09-17-2007   #6 (permalink)
Thats not a bad idea DBL and i will if i have to. However, i'am a firm believer in keeping ALL your stock parts. Ya just never know. I believe the S3 is a modern day classic and i would hate to not be able to turn it back to stock if need be.
How many classic cars and bikes restotoration have been ruined or come to a halt because unpopuler at the time stock items were binned. The 63 split window vette had a kit to eliminate the middle body part. The 71 superglide with the boattail.etc..........
Electrical Connectors - Tail Light Pict Twins Technical Talk 2 08-23-2006 05:49 AM
Electrical connectors b50bsa Sprint Forum 2 06-10-2006 08:08 PM
electrical connectors jaben Hinckley Classic Triples 3 05-22-2006 07:43 AM
HELP - WHAT are these electrical connectors??? kballowe Twins Talk 4 04-30-2006 12:39 PM
Electrical connectors on Bonneville norse Twins Talk 8 02-10-2006 08:00 AM
