The stock Triumph tunes (both bone stock & TORS) are horribly lean from 3500-5500 RPM, and could cause the miss you're talking about. If you buy cheap gas regularly, or even from time to time, run some injector cleaner thru it just to make sure, but I'm betting a tweaked Arrow TuneBoy tune would do you much better. If you know someone with the cable, just buy a key ($200AUD) and borrow the cable...
Two Bros V.A.L.E and TORS Tune
Renthal Street Ultra-Low bars
CRG barends
Pazzo Racing levers
Underseat Cleanse
It's a fine line between smooth and not-so-smooth... -JM
