Motorcycle.comBikeBanditAdvanstarMotorcycleShowsTrident-Exhausts.com
Old 09-04-2007   #1 (permalink)
DGA
DGA's Avatar
Helmet Lock
Hi,
Anyone have one on their '05+ 1050? If so where did you mount it?
Thanks
-D
DGA is offline   Reply With Quote
Old 09-04-2007   #2 (permalink)
Favorite Bike: 2006 Triumph Speed Triple
BigRedandRiding's Avatar
Other Motorcycle: 2003 Triumph Speedmaster
I was wondering the same thing... I'm thinking the frame between the seat and the tank... but then there's the exhuast to worry about.
Anyone have first hand experience?
BigRedandRiding is offline   Reply With Quote
Old 09-04-2007   #3 (permalink)
Favorite Bike: 03 tbs
helmet lock
I have a helmet guardian on mine. It attaches behind the license plate, and has 2 helmet locks, one on each side. I think they're about 55 bucks. You can get them through Sport Touring Accessories or Cycle Gadgets. Very useful and doesn't look bad either.
super 3 is offline   Reply With Quote
Old 09-04-2007   #4 (permalink)
Originally Posted by DGA View Post
Hi,
I took an 8mm allen head bolt, screwed it into the front side bolt hole for the grab bar using a lock nut and then use a helmet extender to slip over the allen bolt. Works great other than the seat being finicky about latching at times depending on where the helmet extender sticks out from underneath.
silly1k is offline   Reply With Quote
Old 09-05-2007   #5 (permalink)
DGA
DGA's Avatar
Great thanks! Your helmet does not rest on the pipes at all?
Old 09-05-2007   #6 (permalink)
Favorite Bike: 2007 S3
Other Motorcycle: Cb350
I use a looped cable and pad lock. I run it through the subframe under the seat. It also will keep my jacket in place by running it through a sleve then through the chin of the helmet.
Kong
"You don't know what you don't know."
Major Kong is offline   Reply With Quote
Old 09-05-2007   #7 (permalink)
It does touch but the muffler are cool enough to touch but not hold shortly after riding. It would be a perfect setup with the 3 to 1 Arrow system.
Old 09-05-2007   #8 (permalink)
Favorite Bike: 2008 Sprint ST
mbonadio's Avatar
I use this. Just attached it to my license plate... Works great for when I wanna leave my helmet secured to the bike while parked (obviously not a solution for riding, but then again why are you riding without your helmet on your head?)
http://www.kuryakyn.com/products.asp?bn=metric&ci=3662
mbonadio is offline   Reply With Quote
Old 09-05-2007   #9 (permalink)
DGA
DGA's Avatar
So you just bolt it between your licence plate and the license plate bracket? No problems with the heat from the muffler?
Old 09-05-2007   #10 (permalink)
if your not riding with your helmet on the side of your bike beating up your paint job your not riding!!!
05 Speed Triple
jdub3 is offline   Reply With Quote
Helmet Lock / Helmet Guardian daveysew Sprint Forum 2 05-25-2007 03:03 AM
$1.50 Helmet Lock sweatmachine Twins Talk 9 06-11-2006 07:01 PM
Bolt Lock Helmet Lock? d2mini Twins Talk 13 04-07-2006 07:25 PM
Helmet lock? rkx Sprint Forum 9 08-04-2004 10:01 AM
Helmet Lock Daytona Deliberations 14 07-12-2003 08:36 PM
