BikeBandit
Old 09-04-2007   #11 (permalink)
The SAE (Society of Automotive Engineers) corrections are only for barometric pressure, ambient temperature and humidity to give comparable results on different days. Any good dyno operator SHOULD be doing the SAE corrections so you can make accurate comparisons when you are making changes. However, I have never seen a bike shop dyno with an accurate barometer let alone a psychrometer.
Anybody trying to take rear wheel power and turn it into crankshaft horsepower is just blowing smoke so you have big numbers on the print out. There is no way to accurately know the power losses in the transmission & final drive without doing lots more testing.
dr_gallup is offline   Reply With Quote
Old 09-05-2007   #12 (permalink)
HiVel's Avatar
Having had a bit of dyno time with Cheap and others, I say bogus dyno !
That aint real friend.
Anything worth doing is worth doing to excess!
2007 Tiger "Old Blue"
HiVel is offline   Reply With Quote
Old 09-05-2007   #13 (permalink)
lazarus7's Avatar
picture's worth 1000 words....
"the greatest artists indulge in a culpable rivalry with god" - Stanislas Fumet
lazarus7 is offline   Reply With Quote
Old 09-05-2007   #14 (permalink)
actually... that one's not. It doesn't tell what mods you have, much less what bike it is. How did your peak HP come at over 10k rpm when the stock limiter is at 9450? If you have Tuneboy, you can change the limiter to what you wish, but I wouldn't recommend going over 9950. I don't believe there's no way any S3 would peak at that high of an rpm without changing the cams.
cheapbastard is offline   Reply With Quote
Old 09-05-2007   #15 (permalink)
Looks very fishy.. HP and TQ shouldn't be peaking that high in the RPM range.
drivingon9 is offline   Reply With Quote
Old 09-05-2007   #16 (permalink)
All you need is a Tuneboy to raise the rev limiter... I raised mine to 10k without any adverse effects. As long as you're not slapping off the rev limiter all the time its no biggie.
Anyway, unless you've got some new and improved stock bike, all the people I'd seen before with 05/06 1050's were getting 113-118hp with their bikes in stock form. Even the TORS and other exhaust systems were only giving a few extra HP. It wasn't until Devi did a pile of header and intake mods that he got up to 130hp at the rear wheel.
Old 09-05-2007   #17 (permalink)
Red face Thats what it says...honest
He did 10 runs, the last 4 were graphed. They are very consistant. Dont know how the box works, but thats what it said. He does tech support for Dynastar and seemed to know what he was doing (I certainly didn't). Most of the bikes that were done that day seemed to be within the ballpark.
stay safe;
paulB
06' Triumph Blue S3
24 hours in a day, 24 beers in a case. Coincidence? I think not!!
fire911 is offline   Reply With Quote
Old 09-05-2007   #18 (permalink)
lazarus7's Avatar
only performance mods are arrow carby twin highmounts
and latest triumph map...
about 8,000 miles on 06 speed triple bought new by me in dec. 05...
broken in by the book, ridden aggressively but not abusively...
thats the third run on that dyno, baselined stock at 113 and change...
Old 09-05-2007   #19 (permalink)
lazarus7's Avatar
excuse me, 117 and change....
and there is no power commander/ tuneboy;
stock blackbox w latest triumph tune loaded...
Old 09-06-2007   #20 (permalink)
HARVEE's Avatar
what would be the benefit of raising the rev limiter to 10 k. ....as peak hp is made well before?
HARVEE is offline   Reply With Quote
Dyno results oil-spitn-rat Hinckley Classic Triples 6 02-10-2008 12:24 PM
dyno results trumpete The Rocket Science Forum 4 11-17-2007 11:16 PM
Dyno Results. Silver Streak Sprint Forum 0 10-03-2007 08:40 AM
Dyno Results TrackerOldGuy Speed Triple Forum 17 08-18-2006 06:08 PM
Dyno results and info here. tsc17 Speed Triple Forum 23 08-04-2006 12:19 PM
