Scratched wheel - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Old 08-30-2007, 02:26 AM   #1 (permalink)
Scratched wheel
So I rigged my paddock stand (with a steel stake) to work with the single sided swingarm. Unfortunately, I had an attachment on my stand that interfered with the wheel (I didn't notice at first), which I later removed. Too late, however, since it left a couple of pretty nice scratched on my wheel.
I cried
What are my options, short of buying a new wheel?
Will powdercoating the wheel "fix" it? Any spray/touch-up alternatives I can use to spot fix it?
Thanks for any suggestions. Think I'll go cry some more.
drivingon9 is offline   Reply With Quote
Old 08-30-2007, 07:27 AM   #2 (permalink)
bkrbil's Avatar
Powdercoating will be less expensive than replacing the wheel, and gives a much more durable finish than stock.
2007 Triumph Rocket III, 2006 Triumph Speed Triple, 2004 Honda NRX1800 Rune, 2002 Honda GL1800 Gold Wing, 1998 Honda GL1500CT Valkyrie & 1988 Honda CBR1000 Hurricane
and my wife's
2005 Honda VTX1300R & 2004 Honda VT750CA Aero
bkrbil is offline   Reply With Quote
Old 08-30-2007, 09:19 AM   #3 (permalink)
Favourite Bike: Speed Triple 1050
Other Motorcycle: TTR 600 Yamaha Dirt bike
Extra Motorcycle: WR400 Yamaha
It would depend how deep the scratches are, if they are not too deep powdercoating alone would fix it. If they are deep into the the wheel its still fixable it would just have to have some filler. Normal car filler isn't recomended because of the heat the coating is baked on at. But the coaters will be able to sell (or tell) you what heat resistant filler to use.
We get heaps of stuff coated ( www.integritystrength.com ) and when we want a realy nice job we get a clear coat applied over the top of the original coat. But beware...not all coating colours or clears are particularly well UV stabilised, so be sure to ask the coater for advice on that one. Good luck!
The clutch is the one on the left side...Isn't it?
My Photos
INTFIT is offline   Reply With Quote
Old 08-30-2007, 11:19 AM   #4 (permalink)
Great! Thanks for the info!
That does make me feel a little better.
I'll save it as a project for the winter.
Old 08-30-2007, 02:54 PM   #5 (permalink)
Favourite Bike: 2007 Speed Triple SE
j3t black's Avatar
Other Motorcycle: 2004 GSXR 1000
Extra Motorcycle: 2001 Yamaha 426 Super Motard
I put a couple of small scratches on my wheel changing the tire. I just used a Sharpie to fill them in for the time being, which has turned into 3 weeks. I can't even see where the scratches are any more. Keep in mind they are SMALL scratches.
i"M SPecIal
j3t black is offline   Reply With Quote
Scratched windscreen help!! ambajack Twins Technical Talk 7 07-25-2007 04:39 PM
scratched tank wookie Speed Triple Forum 7 04-19-2007 01:35 PM
Scratched Tank bvivers Speed Triple Forum 4 04-05-2007 10:23 PM
Downpipes scratched at dealers? eagle Twins Talk 1 08-10-2006 11:04 AM
Fairing scratched Shavey Daytona Deliberations 0 04-27-2004 04:31 AM
