Yikes...if that's the case, then that would suck arse! Replacing fork seals is a pretty time-intensive task (I've only done it on an old FZR project bike I owned).
Then again, I don't se how a fork seal would start leaking after only a years worth of usage (assuming it wasn't wheelied). I would make the claim that something else is defective and causing the seal to leak.
Either way, it sounds like a PITA.
