Ignition Switch causing rear electrics to go out - Triumph Forum: Triumph Rat Motorcycle Forums
Old 08-28-2007, 02:55 PM   #1 (permalink)
anyone heard of this? i've FINALLY tracked the problem to a faulty ignition switch. has anyone else had all of their lights on the rear of their bikes go out because of the ignition switch? and if so, what did you do to solve the problem? i dont want to take it in to the shop so what are my options? thanks.
bikeordie is offline   Reply With Quote
Old 08-28-2007, 10:50 PM   #2 (permalink)
had the same problem with mine. The dealer fixed it under warenty. The ignition switch comes as a complete lock set and is a bit pricey. Mine was actually the wires that come out of the bottom of the switch, which were pinched bu an overtight wire tie. It only took 2 trips to the dealer and finaly leaving it for 3 weeks to fix it.
sailfish14 is offline   Reply With Quote
Old 08-29-2007, 12:58 PM   #3 (permalink)
yes...
this is what i am afraid of. unfortunately, my bike is out of warranty. i might just have to order an aftermarket ignition switch and rig it under the seat or frame or something. not looking forward to it.
Old 08-29-2007, 01:09 PM   #4 (permalink)
Favourite Bike: Speed3 -09
Martin_R's Avatar
Best check the easy things first before taking it to the shop for a fix.
Like said above, check points where wires are ziptied together for worn through wires. Another common place where wire problems start is the bundle of wires that is clamped to the right side of the steering head. The wires inside the black cover can wear through and start shorting to the frame or on each other.
Have you checked the wires that go to the switch with a multimeter?
Martin_R is online now   Reply With Quote
Old 08-29-2007, 02:18 PM   #5 (permalink)
no, not yet. but when i wiggle the wires going into the ignition switch, the rear lights come on, but then usually go back off after a bit. i'll try inspecting the wires first to see if they are shorting out. great idea.
Ignition Switch - HELP stamp Trophy 3 11-09-2007 12:34 PM
Ignition Switch loski67 The Rocket Science Forum 10 06-24-2007 09:19 AM
Kill switch versus ignition switch? boredinocala Sprint Forum 13 09-10-2006 10:03 PM
ignition switch Spyke Maintenance & Workshop Talk 2 08-07-2006 08:59 AM
remove ignition barrel from ignition switch? kanoa Classic, Vintage & Veteran 3 07-13-2006 01:50 PM
