Although it sez an amount. THere are actually 3 amounts... 1) dry, 2) wet change no filter, 3) wet change with filter. The service manual lists them all - in all 3 cases, the best thing to do is to fill with 3 quarts, wait, run engine short while, check and adjust. That's the only way to be sure you'll have the right amount and not blow seals.
Peet
