Originally Posted by Max_NYC
I have no idea but I will have someone check this out for me. (I'm the worst mechanic on earth). Thanks.
On my S3 the forward threaded bar on the gear change knuckle joint was loose for quite a while before it finally fell out. Managed to get it into 1st and ride home (short distance luckily). I checked both ends of the gear change linkage and loctited them in.
I think that big spongy washer may mask the problem if the threaded bar is loose.
After fixing it the gear change seemed better and crisper, certainly into 6th.
I keep a watch on the linkage now, could ruin your day on a busy freeway.
It's easy to check, there is a little pin that circles the knuckle joint at either end of the gear change linkage rod. The pin also goes thru a hole in the joint. Remove the pin carefully and then with a good tug you can pull the knuckle off the ball at the end of the threaded bar. Remove the big sponge washer and check the threaded bar to see if it's loose in the lever on the splined shaft (the shaft that goes into the gearbox). If it's loose tighten it and reassemble, preferably loctite the threaded bar in.
This process can be repeated on the knuckle joint at the rear end of the gear change linkage rod.
Good luck.
