Originally Posted by Adonus
Hi all;
Trying to figure out what would be the best oil to put in my S3. Currently I am using 10W40 Mobile1 full synthetic. Anyone have any preferences? If so, why? Also, any reason why I shouldn't use 10W40?
On a side note, what do you all use to take the oil filter off/on with? The way it sits up into the pan, its a pain to get ahold of... I am thinking the filter wrench that uses a rubber strap. Ideas?
Thanks....
I use Triumph labeled Mobil 1 15w/50 because I have 5 gallons of it sitting in my garage that I bought "cheap". It is good oil, but is pricey even by 15w/50 full synthetic motorcycle oil standards.
If you are particular about using "motorcycle specific" oil, then any of the full synthetic brands will fit your bill--depending on how much you want to pay.
Some will say use car oil, and others say avoid it due to friction modifiers, clutch slippage, and a variety of other reasons--real and imagined. I'm not going to go there.
As far as an oil filter wrench goes, you only need it to remove the filter--so nothing fancy is really necessary as long as it gets the filter off. I use an old flat honda filter wrench that fits the base of the filter.
Welcome, and enjoy your bike!
