OIL level - Triumph Forum: Triumph Rat Motorcycle Forums
Old 08-06-2007, 03:14 PM   #1 (permalink)
Squidward's Avatar
OIL level
Hey guys I just found out that I overfilled my oil. WHat should I do? Is this bad? what will happen to my engine? Could I file a warranty claim.
Squidward is offline   Reply With Quote
Old 08-06-2007, 03:22 PM   #2 (permalink)
Favourite Bike: 01 Aprilia RSV Mille
eyeque's Avatar
Other Motorcycle: 06 Daytona 675
Extra Motorcycle: 06 Triumph S3
don't start it, drain it. Refill to spec. You overfilled it, it's your fault...therefore, no warranty claim.
eyeque is offline   Reply With Quote
Old 08-06-2007, 03:23 PM   #3 (permalink)
No problem dude, relax.
Just undo your drain bolt a little at a time....little by little until the oil starts to trickle out in the drain pan. Drain some, then re-check it. Fill it back up the right way.
dblhelx is offline   Reply With Quote
Old 08-06-2007, 04:30 PM   #4 (permalink)
Squidward's Avatar
But i've been running my bike for a few thousand miles with it like that, it doesn't seem to have any trouble, but i"m worried now.
Thanks for the replies
Old 08-06-2007, 04:43 PM   #5 (permalink)
Favourite Bike: 2007 Speed Triple SE
j3t black's Avatar
Other Motorcycle: 2004 GSXR 1000
Extra Motorcycle: 2001 Yamaha 426 Super Motard
When I picked my 07 up from the dealer I rode it home and to a few friends houses to show her off. The next day I noticed oil on the side of the clutch cover. I cleaned it off and thought maybe they were a bit sloppy at the dealers. Turns out they must have filled the bike on the side stand because there was about 1 quart to much in there. The oil was actually overflowing out of where the clutch cable connects it was so full. It's not great to have to much oil but I wouldn't think you've done any serious damage. Better to have too much than too little.
i"M SPecIal
j3t black is offline   Reply With Quote
Old 08-06-2007, 05:10 PM   #6 (permalink)
if you had TOO much, I mean really too much you could blow seals and develop a serious leak, etc. Also, if your oil is too high there are parts inside that could whip the excess oil around they sort of "dip" into the higher level of oil and whip the oil around. That can cause the oil to become aerated, frothy. COULD be a problem. Don't sweat it man. You would have noticed a problem by now.
Drain the oil! Don't nickel and dime it. Refill it to correct level. When you CHECK and refil the oil, so it when it's centered/upright.
Old 08-06-2007, 05:16 PM   #7 (permalink)
Talking
Set fire to it an file an insurance claim.
Sarcasm. Is just one more free service I offer.
Limey is offline   Reply With Quote
Old 08-06-2007, 05:26 PM   #8 (permalink)
Favourite Bike: Speed Triple, baby
R100Pilot's Avatar
Other Motorcycle: R100RS, 1050 Sprint
Extra Motorcycle: TT600 - Spongebob
The bike is toast. I'll give you $500 for it.
"I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me."
— HST
R100Pilot is offline   Reply With Quote
Old 08-06-2007, 05:36 PM   #9 (permalink)
She's gonna blow!
6485 is offline   Reply With Quote
Old 08-06-2007, 05:53 PM   #10 (permalink)
The bike does sound like it's done. Just bad luck. But to offer him $500? friggin' insulting bastid! I'd give you the fair value of $999 for it. Just want to be fair, that's all.
oil level pz1 Twins Technical Talk 12 06-24-2007 09:07 PM
Fork Oil - Increasing viscosity and oil level? NikosR Sprint Forum 9 04-21-2007 05:12 PM
Oil level kan4132 Twins Technical Talk 4 08-02-2006 01:14 PM
Oil level Isa Sprint Forum 1 11-13-2005 12:52 AM
Oil pressure light/oil level pigpen955 Tiger Workshop (archive) 5 03-16-2005 09:09 PM
