So the clutch switch was off and not sure how to keep it tight but I now have a new problem:
My bike has been starting like this:
crank,crank,crank,crank,crank,crank,crank,crank,cr ank,crank,crank,crank,crank,crank,crank,crank, i give up after 10 secs thinking I'm hurting the starter
then try again:
crank,crank,crank,crank,crank,crank,crank,crank,cr ank,crank,crank,crank,crank,crank,crank,crank, after 10 secs i give up again
then:
crank,crank,crank,crank,crank,crank (5 secs)- and then it barely fires and revs below 2k for a few secs.....then it comes to life.
Changed the tune to Wayne Macdonalds, with SAI and it seemed to help but then I went on a trip North into Pa and had a hell of a time starting it cold or hot. sometimes sounded like a metal wack! happended. Mostly it was hard starting after resting on the side of the road for about 10/15 mins. It is getting embarrasing and I feel like the bike is becomming unreliable
