Rizoma / Triumph fat bar alternative. - Triumph Forum: Triumph Rat Motorcycle Forums
Old 08-05-2007, 10:15 PM   #1 (permalink)
w00ht's Avatar
Here are a couple pictures of my Pro Taper install on my 07 Speedy.
I went with the Pro Tapers for a few reasons, most of which is I knew the bend since I have ridden it before. The stock bars had too much sweep for me, so it was hard to keep my weight forward since my elbows tended to tuck into my sides keeping me further back. I tried looking up some of the bend info for the Rizoma's and Triumphs but in the end the Pro Taper web site has much more info and they are in stock at my local cycle gear. Not to mention they are a lot cheaper! I'm happy with the end product but I did have to make a couple parts to make everything work. I ended up making a spacer for the hole where the stock riser sits in the top clamp; I also had to shape a shorter bolt to work with the Pro Taper risers since the supplied hardware was too long for speedy's top clamp. This really wasn't a big deal, but I like to do this type of stuff. If you don't want to mess with it just order the Rizoma conical risers and bolt up your 1-1/8 bar of choice. However if you order them form PJ's they are $91 US, that's what my bars and adapters cost together.
w00ht is offline   Reply With Quote
Old 08-05-2007, 10:31 PM   #2 (permalink)
Favourite Bike: 2007 Speed Triple SE
j3t black's Avatar
Other Motorcycle: 2004 GSXR 1000
Extra Motorcycle: 2001 Yamaha 426 Super Motard
What bend are those? I have a set of Carmichael bend pro tapers that I've never installed on my RM 125. I was thinking of putting a set of Tag metals bars on my 07 S3, But the're almost a blue and the Pro tapers are black....I'm torn
i"M SPecIal
j3t black is offline   Reply With Quote
Old 08-05-2007, 11:23 PM   #3 (permalink)
w00ht's Avatar
They are the Carmichael bend. The Henry/Reed has more sweep and is closer to stock.
Old 08-05-2007, 11:33 PM   #4 (permalink)
Favourite Bike: All of them
NinjaRAT's Avatar
Other Motorcycle: '06 Black Speed Triple
Extra Motorcycle: '06 Sunset Red Sprint ST
Looks good!
Did you end up drilling holds to support the nubs on the signal controls, or were they already pre drilled? When I upgrade my bars, I've been debating what to do (drill, or remove the nubs and apply friction tape).
As long as your speed limit is greater than your age, you're good to go!
My Gallery Old Gallery
http://www.danasoft.com/sig/BikeforLife.jpg
NinjaRAT is offline   Reply With Quote
Old 08-05-2007, 11:52 PM   #5 (permalink)
w00ht's Avatar
I used a drum sanding bit on my dremel and took the nubs off. The screws alone have plenty of holding power for the light plastic switch housings. I actually have a few turns left so I can continue to tighten them up as time goes on if I need too.
Old 08-06-2007, 06:51 AM   #6 (permalink)
NinjaRAT's Avatar
Figured that would be a safe bet, though a few wraps of friction tape wouldn't hurt either. I recall seeing on the TBS forums a post by a guy who created some sort of template for drilling the holes on his replacement bars. Didn't look to be easy to find a point of reference, though.
Another silly question, but what are the numbered markers on the bars near the risers? Rizoma's have them also. I suspect it indicates how the bars are aligned in the riser clamps?
Old 08-06-2007, 06:53 AM   #7 (permalink)
NinjaRAT's Avatar
Sorry, another question: what riser (looks like powertap, or something) are those and do you know their height?
Old 08-06-2007, 07:30 AM   #8 (permalink)
w00ht's Avatar
Pro Taper bars, Pro Taper risers. I don't know the height off hand, but I'd say they are 3-5mm lower then stock when installed on the bike.
The marks give you a point of reference for center and angle up an down. The little squares let you center, the numbers help you figure out angle
Old 05-06-2008, 04:11 AM   #9 (permalink)
Favourite Bike: 07 Speed Triple
nodrog's Avatar
hi, what bar ends did you use? i am putting pro tapers on my 07, and need to get some bar ends basically the same as the stock ones, so i can still use my crg bar end mirrors.
nodrog is offline   Reply With Quote
Old 05-06-2008, 01:26 PM   #10 (permalink)
Favourite Bike: Speed Triple 1050i
I'm cheap.
I have these, got em on sale for $15.00
iconhttp://www.bikebandit.com/product/A4758823
I had bought them for my Bandit and never installed, and when I had my oops.. and bent the stock bar, these fit like a champ, and of course they are black..
Photo:
Mini4x is offline   Reply With Quote
Triumph fat bar help jbowen Speed Triple Forum 6 01-06-2008 02:26 AM
Triumph fat bar riser height NinjaRAT Speed Triple Forum 9 08-24-2007 03:47 PM
Triumph 'Fat' bar....R&G ends wingedwraith Speed Triple Forum 3 08-21-2007 01:58 PM
Rizoma Fat Bar and Risers Install Tips dblhelx Speed Triple Forum 27 08-15-2007 11:28 AM
Rizoma fat bars? Spendthrift Speed Triple Forum 2 02-06-2007 05:31 PM
